SpaceX Animation Shows Musk’s Roadster Aboard Rocket
[vc_row][vc_column][vc_column_text]Ahead of Tuesday’s planned launch of the Falcon Heavy, SpaceX has released a simulation video of the mission.
The payload for the mission, Elon Musk’s Tesla Roadster, is shown floating through space with a space-suited mannequin at the wheel. It seems SpaceX actually place a mannequin in the seat. Musk shared pictures of “Starman” on Instagram.
https://www.instagram.com/p/BezcvpzAgYI/?taken-by=elonmusk
Falcon Heavy is set to launch Tuesday at 1:30pm EST at Launch Complex (Pad) 39A in Cape Canaveral, Florida.
Below is SpaceX’s description of the mission and the animation.
When Falcon Heavy lifts off, it will be the most powerful operational rocket in the world by a factor of two. With the ability to lift into orbit nearly 64 metric tons (141,000 lb)—a mass greater than a 737 jetliner loaded with passengers, crew, luggage and fuel–Falcon Heavy can lift more than twice the payload of the next closest operational vehicle, the Delta IV Heavy, at one-third the cost.
Falcon Heavy’s first stage is composed of three Falcon 9 nine-engine cores whose 27 Merlin engines together generate more than 5 million pounds of thrust at liftoff, equal to approximately eighteen 747 aircraft.
Following liftoff, the two side boosters separate from the center core and return to landing sites for future reuse. The center core, traveling further and faster than the side boosters, also returns for reuse, but lands on a drone ship located in the Atlantic Ocean.
At max velocity the Roadster will travel 11 km/s (7mi/s) and travel 400 million km (250 million mi) from Earth.
[/vc_column_text][vc_video link=”https://www.youtube.com/watch?v=Tk338VXcb24″ video_title=”1″][/vc_column][/vc_row]
NeverFollow
1,277
730
Might launch Feb 6th?
I hope the Roadster will have a Dashcam!
Tex EV
252
406
Houston, TX
Beautiful video. Think I got some sawdust in my eye while watching. And I haven't been near a saw since yesterday. Feel like I'm 12 again and dreaming about being an astronaut after visiting the Johnson Space Center and hearing a NASA employee say that my generation would be the first on Mars. They said the same thing about my 4-year-old's generation when we went back last year. Jerks.
gregd
2,524
1,755
CM98
Hmmpf... last tweet was 17+ minutes ago; no word yet.
Curious, they keep saying the Roadster is in LEO. Presume another burn is needed to send to Mars? When?
Reactions: MrBilly
LCR1
1,322
970
Houston
When they hit perigee of the intended orbit. What ever adjustment you make here effects you on the opposite side.
So imagine a circle; if you're at 180* (bottom) and you want to make an adjustment to your altitude at 270* ( left side) you need to wait until you're at 90* (right side) once you get to the desired altitude at 270* in your circle you'd then burn fuel there and it would effect your altitude at 90* and you'd then make a perfect circle.
That's the basics of designing an orbit around a single body (earth) once you try to orbit the moon, mars, or the sun (independently of any other body) you get a little more complex. If you're a computer guy and have the time to play games, get Kerbal Space Program (KSP) I've literally wasted 20+ hours in a day playing it.
gregd
2,524
1,755
CM98
Ah, of course.
It's a bit odd that they signed off so quickly, without waiting for the status of the core landing, and the second second stage burn. They always do that for the commercial launches.
SteveG3
4,013
15,353
US
yes, apparently about 6 hours after launch. from an ars technica interview with Elon released today,
"After the launch and six-hour cruise, the Falcon Heavy’s upper stage will fire a third time to send the Tesla into a cycling orbit between Earth and Mars. This should take the Tesla out as far as the Martian orbit around the Sun, or even a bit further. Musk said the vehicle should get as far as 380 to 450 million km from Earth, depending on how the third burn goes."
Elon Musk says the Falcon Heavy has a 50-50 chance of success
