Analysis
Tesla Cybertruck & Semi: Radical New Battery Design Anticipated
Check out our fun speculation based on known quantities.
Tesla has something up its sleeve and, as usual, it’s not telling anyone about it yet. We should get a better idea of what it is at the upcoming “Powertrain and Battery Day” that Tesla has planned for later this year.
Tesla has given us some strong hints so far: it seems all but certain it will make its own line of batteries (ref), and that these new batteries will be manufactured with a completely new process. Witness Tesla’s purchase of Hibar, a company that makes custom battery manufacturing equipment and its purchase of Maxwell, with its new dry electrode manufacturing process (ref). Now, mix that with Tesla’s patent application for a whole new manufacturing method for battery packs (ref).
No longer will we have two separate manufacturing processes where one plant makes cells and another makes packs. Tesla’s new approach will integrate the two manufacturing processes into one. We speculate that what comes out of the plant won’t be individual cells, it will be small cell groups. These small cell groups will be assembled like Lego blocks into whole battery packs.
What about the cooling system? We are going to go out on a limb here and speculate that Tesla will ditch its current “cooling snake” concept where the cooling tube is glued directly to the cells.
If the cooling snake is out, then how will they cool the cells? We think the answer is hidden in two places: Tesla’s patent app and Rivian.
What do Rivian, the Tesla Semi truck and the Cybertruck have in common?
They all stack batteries. Rivian’s system uses a flat plate in between the two layers of batteries … a perfect solution when you are stacking layers of batteries.
The only problem is that the flat plate cooling concept does not cool nearly as effectively as Tesla’s cooling snake, where cells are glued to the cooling tube. That brings us to Tesla’s patent application where it talks about using an engineered dielectric fluid for the cooling fluid. The battery cells are directly immersed in the cooling fluid, thus providing great heat transfer.
The cooling fluid for the cells surrounds the cells and is either circulated through the pack as illustrated in the patent app or does not circulate except for natural convection within the pack modules. We suspect this is what Porsche is using to make its flat plate cooling system work in Taycan and what Audi is using in its SUV. So, picture no cooling snake, but instead, a flat cooling plate, and/or an engineered fluid.
What about the cells? We speculate Tesla will use thicker electrode cells made with Maxwell’s dry electrode manufacturing process for increased energy density using today’s chemistry. Thicker electrodes mean lower C rates. That’s why the Cybertruck and Semi are perfect applications … because they have big batteries (lower C rates). We are estimating 250 kWh for the Cybertruck 500-mile variant (ref) and 900 kWh for the 500-mile semi. Also of note, Electrek just reported that a hacker has found evidence of a 100 kWh battery for Model 3 (ref).
The other thing big batteries have going is that they have lower internal resistance, so they generate less heat and don’t require as much cooling.
In short, a whole new way of making battery packs that ditches today’s pack architecture and significantly lowers cost with a whole new manufacturing process.
Do you have your own ideas about where Tesla is headed in the battery department?
Let us know in the comment section.
duncan
14
15
East Gore
The Chevy Volt uses pouch type cells - and uses a circulating coolant between the cells
It's replacement uses similar cells but sits the cells on a cooling plate and uses aluminium fins between the cells to conduct the heat to the cooling plate
This looks to me as if Chevy started off with a very very effective cooling system - (after the Leaf showed that was needed) and after actual production experience has decided that was overkill and gone down a notch
Tesla have vastly more experience - and I suspect they have also decided that their current cooling system is also overkill
doghousePVD
My grandfather’s car
Dec 3, 2018
572
463
New England, USA
Hard to imagine “overkill” with track mode, summer use in AZ & TX, trailers, etc. Perhaps not cheap enough, but not overkill.
electracity
4,028
2,531
60606
Maybe, but it's really a "temperature distribution system" to and from the battery and other bits. Reducing battery cooling capacity decreases the speed at which the battery can be both cooled and warmed.
duncan
14
15
East Gore
I did not make myself clear - the changes may not and probably will not effect the amount of heat that can be removed - but they may increase the temperature spread inside the battery -
nickysg
singapore
I wrote about the Battery Investor Day recently:
https://seekingalpha.com/article/4311959-battery-developments-coming-thick-and-fast-for-tesla
I think it could be seminal in the future of the company, and could have a huge impact on the stock price.
Of course the article is wrong in stating the Battery Investor Day is taking place later this year.It was originally scheduled for late 2019 and we do not yet have a firm date for its intended Q1 2020.Elon Musk has a bit of a history of not keeping to his deadlines, but in this case I think they are probably awaiting some definite breakthrough news they can release.
Jackl1956
1,788
11,335
Los Angeles
I’d like to see your article as a TMC blog.
