Tesla Cybertruck Could Be Tempered For Unique Colors Or Tattoos
When you heat cold-rolled steel, you get various colors. Elon Musk says this is possible with the Tesla Cybertruck.
The Tesla Cybertruck is unique in that it isn’t painted. Instead, it is just the color of stainless steel. Of course, people can choose to modify the Tesla however they want. More than likely, many folks will wrap their Cybertruck. This allows them to choose the color of their liking, it protects the vehicle, and it’s reversible. When they get tired of one color, they can remove it and wrap it in another.
CEO Elon Musk mentioned the potential for a matte black Cybertruck. Other color options have also been suggested, so we don’t know with 100-percent certainty that the electric pickup truck will only be available in one color. Recently, Twitter user Ghost of Tesla Phx (@Ghost_TeslaPhx) took to Twitter to beg Musk for a white oxide Cybertruck. Musk said it wouldn’t be impossible.
As usual, due to Musk’s massive number of followers and seemingly constant Twitter engagement, this fired up a conversation. Apparently, if you temper (heat) the Cybertruck’s cold-rolled steel, you can get different colors.
Avid Tesla fan and Musk supporter Viv (@flcnhvy) tweeted the following:
Musk’s response was simply “yes,” likely meaning he agrees with Viv that it is, in fact, possible. For clarification of the potential color rainbow, K10 (@Kristennetten) replied with the tweet below:
Even more interesting is the fact that you could use a laser to heat parts of the steel and create a tattoo of sorts:
We’re pretty confident Tesla won’t offer any of this at Cybertruck production. However, you’d better bet on the fact that the aftermarket industry will get involved quickly if this is something that is truly viable.
As always, feed us with your wisdom in the comment section below. Is this something that’s bound to happen?
CyberGus
Not Just a Member
May 5, 2020
718
1,594
Austin, TX
Once, I cleverly put my stainless cookware though the oven-cleaning cycle (high-temp). If it can clean the oven, it will clean the pots and pans, right?
And it did! They also donned a pretty rainbow of colors. And warped. Which was fine, because the rivets melted.
So sure, you can heat-treat to new colors, but getting a single uniform color would be challenging. And temperatures high enough to change the color may also change other chemistries, possibly altering the strength characteristics...? A wrap seems more sensible.
Laser etching sound cool, tho. Maybe they'll even do the badging that way.
TechOps
194
218
Austin, TX
The laser etching idea is cool, and how Tesla could potentially put a logo / label on the car. Heat treating/tempering the steel is also cool, though it seems easiest to do before the car is put together, otherwise you could potentially melt some important components below the steel.
Titanium bicycles have been using the anodizing process to make really vibrant color designs for a while. Basically, chemicals and electric voltage are used to create varying thicknesses of titanium dioxide on the surface of the metal. Those different oxide thicknesses refract different wavelengths of light, creating color. Not sure this could be done on the steel to be used on CT. Maybe? Here's an example video/article: link.
More cool photos: link
Reactions: MichaelP90DL
