People argue that if the results are professional and precise, it makes no difference what method is used for your paint protection film installation.
But if you’re wondering what really happens during an installation, this won’t win you over. You’ll want to understand bulk and pattern methods – especially since one involves using a sharp cutting tool directly on your Tesla.
What is bulk installation?
Also known as custom install, the bulk install method requires little to no technology and a high level of skill. The installer cuts sections from a bulk roll of PPF and places them one at a time, on each car part that will be protected. Once in place, each section is trimmed by hand for a custom fit. To do this well, you need a steady hand and a great deal of experience.
What is pattern installation?
A pattern install requires technology. The installer uses software loaded with a library of patterns designed for a car’s year, make and model. Once a pattern is selected and prepped, it is sent to a machine that cuts out a separate piece of PPF for each car part. To do this well, you need experience with both software and film application.
The Pros and Cons
Bulk installs typically require more film product, take longer, and therefore cost more than pattern installs. And what if your installer’s hand slips? If you’re working with someone good, they’ll cover the damage. So all things considered, you still might love the idea of an old school, handcrafted approach to PPF. Or you might have an exotic car or aftermarket customizations for which no pattern exists.
Fortunately, patterns can be edited, and many pros are skilled at this. Plus, the technology involved in the pattern install process saves film and time, and usually costs less. But this same technology can cause problems, wasting film and time that will drive costs up.
It’s essential to have accurate, well-made patterns and software that allows installers to edit and customize fit. This is precisely why Eastman, maker of SunTek® PPF, is rolling out a revolutionary system called Core to offer installers all the benefits of technology, without the downside.
Making Your Choice
SunTek believes in the integrity of both installation methods, so we’re solidly neutral in this debate. With equal PPF quality and an expert installer with years of practice, it’s nearly impossible to tell the difference between a bulk install and a pattern install.
What about you? Are you in the camp of “no sharp objects anywhere near my car”? Or do you like the idea of expert handwork best? State your case in the comments.
Ready to protect your Tesla? Find a SunTek Dealer
