‘18 100D Battery in cold weather problem (Regen related)
Discussion in 'Model S' started by Pwdr Extreme, Dec 3, 2018.
  1. chillaban
    chillaban Active Member
    Bay Area
    I see the same behavior in my '17 S100D this winter but I didn't see it when I first took delivery of the car.
    I suspect recent software updates have changed the regen limiting behavior to be more prone to limiting regen. One can only speculate why they did this.
  2. SeminoleFSU
    SeminoleFSU Voluntaryist
    Atlanta, GA
    I'm noticing a difference between my old 2013 P85 and new 2018 100D. Takes longer from start with cold soaked battery to get full regen, and the limited regen warning seems to come on in much warmer temps than my old car. My first thought was more batteries, same heater=longer time to heat up... but looking at Jason Hughes' teardowns of the newly redesigned 100 packs, he mentions a smaller coolant line being used, but instead of 1 now there's 2 so that the warm coolant doesn't have to travel past as many cells before it gets cooled again. If this closed loop system is used to also heat/warm the pack (not sure just a guess) it could mean the thinner diameter coolant lines are also contributing to the issue. This will be much less of an issue once Tesla releases the update where you can set your charge start time based on when you want it to finish... Well it'll solve the issue for 50% of the time at least.. 100% if you have a charger at work.
  3. Pwdr Extreme
    Pwdr Extreme Member
    Bozeman, MT
    I charged to 100% in my garage yesterday morning, it finished about 30 minutes before I left. I turned the heater on in my car an hour before I left, (which showed battery heating on the app) and I still had limited regen for the full 220 miles until I hit a supercharger. Temps were in the mid 20’s.
    What the hell more can I do? Basically, it seems we will just have limited regen once the temp drops below 45 degrees or so, period. Unless we supercharge often.
    The app never shows my battery heating except when I am plugged in with climate control turned on. I’m guessing Tesla wants an income stream from doing brake jobs. LOL
  4. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    What SoC did you start from, and what charge rate do you have? (The charge tapers towards 100% so it will generate a lot less heat going from 90% to 100% than it would for 70% to 80%. Assuming you are more than trickle charging.)
  5. Jan Fiala
    Jan Fiala Member
    Prague
    Thats pretty normal and as per design. Preheating DOES NOT remove the regen limitation completely but only to achieve 30kW regen. The rest will slowly go away with normal (not city) drive.
    On the other hand, two hours of full AC charging (17kW) removes the regen completely even in freezing conditions.
  6. SeminoleFSU
    Atlanta, GA
    Well you'll obviously be almost completely regen limited at 100% SoC until you pull at least 3-5% (maybe more) out of the battery... but if you did 220 miles and saw limited regen that entire time, then maybe there is something to this... I say that with a grain of salt though because 20 degrees is colder than anything I've had my car in because I live in the South :)
    Perhaps someone should message Bjorn what he's seen with 100Ds? He's a cold weather superstar.
  7. Pwdr Extreme
    Pwdr Extreme Member
    Bozeman, MT
    Started with around 40% charge. Of course it will be limited since it’s at 100% for a little while. But only 15 or 20 miles.
    2 hours of 48 amp charging absolutely does NOT remove regen limiting. Even in my 50 degree garage. 4 hours of 48 amp charging at my office does not remove regen either of its 45 degrees or colder.
    I typically charge from 40% or so to 90% at my office. Sometimes I leave with it still charging at 80ish percent. So pulling it fresh off of full, 48 amp 243 volt charge for 4 hours does not warm the battery enough to prevent regen limiting.
  8. SeminoleFSU
    Atlanta, GA
    #28 SeminoleFSU, Dec 12, 2018
    Yea I just did a quick Chickfila run and yes it was cold last night (not below freezing but my car still is not garaged- it's in carport). The temp is 53 outside right now and I had regen limit the whole way there and back... prob 10m each way stop and go... My old 2013 P85 is still in my muscle memory having drove it 5yrs and 80+k miles... With that being said, my perception is the 100 pack is a lot more regen limited in cold than the 85 was.. Is it software related? Could be. If I hadn't sold my old p85 it would be interesting to compare the behavior of the two esp on the same firmware.. but that's not going to happen now :)
  9. N..8
    N..8 Member
    Sanford, NC
    220 miles driven and still limited regen, something is wrong. Sounds like maybe your Battery coolant heater went out or the switching valve isn't working, bring it into the SC
  10. EVSteve
    EVSteve 110% Solar Powered
    Schnecksville, PA
    I presume you’re referring to Jan’s post regarding two hours at 17kW? 17kW is in the 80A range depending on voltage not 48A.
  11. sorka
    sorka Well-Known Member
    Merced, CA
    You beat me too it. Charge and discharge BOTH cause heat and the 100's increased capacity means the same amount of work is spread over a larger capacity battery.
  12. sorka
    Merced, CA
    Can't you use "Max Battery" to preheat the battery before leaving? I thought non performance models now have the software switch to turn that on?
  13. sorka
    Merced, CA
    The battery heater or the cabin heater?
  14. sorka
    Merced, CA
    My app never shows battery heating even when I've turned on "Max Battery". Cabin heating is not the same thing as battery heating unless there's something new in V9 that I don't know about since I still have V8.
  15. Jan Fiala
    Jan Fiala Member
    Prague
    He is probably speaking of this one year old little heat wave icon on the app climate page which lits when switching on the cabin heating and having a cold battery. This actually is the icon for the battery heater.
  16. Pwdr Extreme
    Pwdr Extreme Member
    Bozeman, MT
    Wasn’t aware of max battery other than P models.
    Yes, referring to the icon in the center of the car on the climate page with the red wavy lines. That icon only shows up when plugged in and I turn on climate control.
    I put a call into Tesla, they are “reviewing logs”
  17. TMeister
    TMeister Gearhead
    Boise, ID
    I have the same behavior as you have described. The regen limiting has changed between last winter and this one to be more limiting for sure. I do not ever get complete regen driving around if temps are in the 30's or lower. And I have gotten no regen when temps are in the low 20's. Although I do get a little after 20 miles or so in that case.
    Yesterday I supercharged to 96%, had full regen, drove around some and parked for the afternoon for 4 hours in 30 degrees. The car still had full regen after that. But then overnight in the garage at 48 degrees, back to limited regen today. Right now at 48 degrees the car shows 4 bars of limit after sitting 4 hours after a short 10 mile drive. So no change at all since this morning. Outside was in the low 40's.
    I only see battery heating in the app when plugged and temps below 20. Cabin heating (plugged in or not) appears to have no effect on regen limits.
  18. Jan Fiala
    Jan Fiala Member
    Prague
    This is weird. I just started to drive after preheating and had 5 yellow bars (30 kW regen). Within 20 miles city drive and 50 min the regen limit was gone completely. 30's F.
    100D, 2017
  19. sorka
    Merced, CA
    Interesting. Never seen it when I use Max Battery which runs the battery heater without heating the cabin.
  20. ytwytw
    ytwytw Member
    Canada
    I have MX100, -3C recent days
    After park my car for whole day, still have half Regen
    30min drive will get full regen
    Never see no regen except park the car outside for 3 days.
