Tesla Model 3 Performance with aftermarket coil overs and sway bars.
My left front coil over has started to make a boing sound when turning the wheel after backing out of my driveway. Pretty much only does it when going from straight to full lock, at low speeds. Everything is installed per instructions; everything properly torqued.
I’ve lubed up the thust washers that the spring rests upon, both the Delrin plastic and stainless steel washers. Still made noise, so lubed up the top of the coil over where it makes contact with the top hats and rubber isolation bushings at the top of the coil overs.
Compared the preload and compression on the left versus right, no difference. But right one does not make a boing noise.
Any recommendations suggestions?
