“HI” Heat
Discussion in 'Model 3' started by BobAbooey, Nov 10, 2018.
  1. BobAbooey
    BobAbooey Member
    usa
    Is it normal when the heat is set to high that it only blows out the foot/lower vents?
  2. CullinKin
    CullinKin Member
    Denver, CO
    From what I’ve experienced it uses your last known settings. So if you have front vents and foot vents and seat warmers, it will turn all of those on. Whoops, at least what I’m referring to is turning it on from the app. If not from the app, do you have the front vents on from menu from touching the fan icon?
  3. BobAbooey
    BobAbooey Member
    usa
    Like when I get in the car and set to HI the air only come out the lower vents? Does ur car blow out the dash vents?
  4. CullinKin
    CullinKin Member
    Denver, CO
    It does. Are you sure you have the dash vents turned on?
  5. BobAbooey
    BobAbooey Member
    usa
    Hmmmm lol I don’t even know. I only use the “auto” setting. I used the app to set HI heat and when I got in the car it was only coming out the lower vents so today I got in and set the temperature up to hi from the screen and it came out the lower vents only again. But when I set to anything temperature lower then hi it blows out other vents. So when you are on auto and set to hi it blows out everywhere?
  6. CullinKin
    CullinKin Member
    Denver, CO
    I never use auto so that may be part of it. I just manually adjust it. Every time I turn on Auto it turns the fans to 9 every time and it feels like a tornado. If you turn off auto, turn on HI and make sure the button I circled in the photo below is blue, it should come out the dash vents. As for Auto, someone else will have to help on that one.
  7. BobAbooey
    BobAbooey Member
    usa
    Thanks for posting that pic. Yes when i don’t use auto it will go to whatever vents I choose, but as soon as I click auto on hi setting back to the floor it goes..
  8. VT_EE
    VT_EE Active Member
    Maryland
    Heat rises. Most cars use the lower vents when running the heater. Totally normal.
  9. Runt8
    Runt8 Active Member
    Colorado
    Mine definitely uses the upper vents when on Auto, although I've never turned the heat up higher than 74.
  10. BobAbooey
    BobAbooey Member
    usa
    Yeah mine is good also below hi but when on “hi” it goes to the lower vents only
  11. BobAbooey
    BobAbooey Member
    usa
    When you turn the heat in ur M3 on “HI” it also comes out the floor vents?
  12. VT_EE
    VT_EE Active Member
    Maryland
    Haven’t tried putting it on hi. When I turn the heat up, the floor vents run.
  13. Runt8
    Runt8 Active Member
    Colorado
    Just tried this, and it does the same thing - only floor vents when on HI.
  14. BobAbooey
    BobAbooey Member
    usa
    THANK YOU ........
