“Systems Are Powering Up. Press Brake When This Message Clears
Discussion in 'Model S' started by cookpwr, Feb 24, 2018.
Tags:
  1. 4SUPER9
    4SUPER9 Active Member
    I spoke to Tesla again today (for another reason) and asked again about this. They are well aware of the issue.
  2. 4SUPER9
    My car is in service right now for several issues, including a crack in my glass roof. The rep did not give me high hopes of a fix. In the meantime, the loaner car I am driving has not shown this error message even once in numerous "starts". My car, OTOH, has almost never failed to show this message.
    The question I have for the group: has anyone achieved a complete fix for this? Sorry, but for me, a fix for this is an absolute requirement for me to consider the car fully functional. I find it absurd that my '49 Buick starts faster than my Tesla.
  3. 4SUPER9
    Update: I just got my car back from service where they uploaded the latest firmware. They said they could not reproduce the issue, but I have it again all day today. Not acceptable at all.
  4. aaron0k
    aaron0k Two failed MCU's on a S40 & S70D; both at 84k.
    Reoccurring blank center screen = MCU/eMMC is on it's last legs. Specifically request that they search your logs for filesystem errors to confirm.
  5. 4SUPER9
    This is not a blank center screen. This is the message that appears on the instrument cluster.
    I called the mother ship today and the person was very responsive. The diagnostic team is searching for a solution. In the meantime, the SC rep was far from helpful, and told me, in writing, that this is normal behavior. I am not happy.
  6. SouthPalito
    SouthPalito New Member
    Dallas
    I’ve had this message reliably show up every day after work, but only when I park the car in an underground garage in the lower levels where cellphone signal is very weak.... My current theory is that the starting routine is halted while waiting for the LTE connection to resume..
  7. 4SUPER9
    Interesting theory. I have terrible LTE signal and both my home and office. I will observe. However, I do know distinctly that this has occurred while I was in a good signal area as well.
  8. whitex
    whitex Well-Known Member
    Seattle area, WA
    It could be. I read that at least the old MCU has no RTC, therefore when rebooting it doesn't know what time it is until it can reach the internet. Not knowing what time it is can make things wait, for example if they sign then code or anything with certificates, since that requires current time+date.
  9. bmah
    bmah Moderator, Model S/X, California Forums
    Lafayette, CA, USA
    Just stumbled on this thread. Weirdly, my (Apr 2015 build) S85D almost never showed this message. Ironically, it's currently in the shop for an MCU replacement (CID was black and non-responsive after a short string of other issues). :( I'm currently driving an almost-brand-new (Dec 2018 build, so AP2.5 and MCU2) S75D loaner and that car shows this "powering up" message fairly frequently, or at least enough to be notable to me. It goes away on its own after a few seconds, so not all that bothersome...just...curious. Good LTE connectivity in my garage.
    Bruce.
  10. DMack
    DMack Member
    Oakland
    Been happening consistently for me since I bought the car in March 2018.
    One time, I was stuck outside my coffee shop with the message, and the only solution was for me to initiate an update (that I had scheduled for 3:00am the next morning).
    Back then, cars with MCU2 could not reboot the system with the scroll wheels method, so the only way i was able to drive away was to initiate the update that gave me that functionality, then reboot my system.
    If I ever need to get in my MS and drive off in haste, I’m in deep *sugar* :)
  11. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    I saw that message when parked for about 40 minutes in a strong LTE signal area, so I also don't think signal strength is the issue. It was very cold though — could that have anything to do with the slow boot-up of the car? If there is a pattern to when I get the message and when I don't, I haven't discerned it.
  12. Davidoconn
    Davidoconn Member
    Virginia
    For what it’s worth I have version 49.20 now and when in Florida I never get the message. When in colder weather in the north I get it constantly. I don’t see why cold weather would matter but I can say for sure it doesn’t happen in warm weather for me.
  13. GreenT
    GreenT verT
    France
    I can assure you it happens regularly in Florida.
    Can also confirm that whenever SC tells you they cannot reproduce a problem, they have NOT tried to.
  14. 4SUPER9
    After a couple of days of testing, I can confirm that this issue seems to have nothing to do with temperature, as it occurs in both cold weather and after a nice day-long soak in a heated garage, nor does LTE strength seem to be a factor, as it occurs with both 4 bars of LTE or none.
    Again, I think this is vehicle specific, as I was driving a loaner that was, as far as I could tell, an identical car, running the exact same firmware, and never once did I get this message over a 2 day period. Not even for a brief second.
  15. Sublimobile
    Sublimobile Member
    Chicago
    2014 p85d here. It's happens to be outside my work all the time. Cell signal is fine. It's pretty cold here since I've had the car.
    It only takes about 5-10 seconds to start up but I'd prefer it to be instant like when I start from home.
  16. JoeMartin
    JoeMartin Member
    Pensacola, FL
    When I first got this message on my 14 P85 the EMMC/MCU failed shortly after. (As in... That same day)
    Got MCU replaced under warranty, had no issues with the message.
    It just appeared again two nights ago, and I've noticed a couple of times where my MCU is completely powered off when I get in the car now.
    I'll be keeping an eye on it, but if I feel my MCU is failing again (The car is on it's third one currently) I will be contacting my service center.
  17. tfinan
    tfinan Member
    Short Hills, NJ
    Tesla S 100D Sooooo slow to start up
    In the other thread on this topic, recent posts indicate that having cabin overheat protection on and manually using fob click to unlock vehicle help shorten this delay.
  18. 4SUPER9
    I can confirm that manually unlocking the car with the fob does absolutely nothing to speed up this process. At least, not on my vehicle.
  19. tfinan
    tfinan Member
    Short Hills, NJ
    Do you have cabin overheat on protection on? There was another post about opening drivers door first, which is not my normal routine.
  20. Fcautela1
    Fcautela1 Member
    Boston
    I have started turning on Fan from app before heading out of house and have stopped seeing the message most of the time. As long as I give the car a few minutes and don’t rush out to it, never failed for me. Also having 3rd party apps constantly communicating with your vehicle, it seems to take less time.
