Unfortunately, I don't have any recommendations in Sac area. We just had an owner from down from Oakland for coilover installation.Any recommendations for installation in the Sacramento area? Also, how long it will take to the installation?
Ok, thanks. Let me get in touch with you when I am ready.Unfortunately, I don't have any recommendations in Sac area. We just had an owner from down from Oakland for coilover installation.
Are the arms/bushings recommended for every MPP coilover kit install? If not, at what point would you want/need anything more than just the coilovers?
I’ve had Ohlins R/T on My previous vehicle, and after about 12,000 miles they would need servicing to get rid of a click noise internally. Parts inside would wear out. That was a pain to do. Remove the suspension and then ship them off and wait two to three weeks to get them back. Do KW coilovers need similar type of servicing to keep them running optimal?
Unfortunately, no one in GA I can recommend that we have worked withshop recommendations for Augusta, Ga , our probably better change in Atlanta?
anything in south carolina by chance?Unfortunately, no one in GA I can recommend that we have worked with
I'd recommend contacting MPP directly, as we're showcasing our installs performed here. They may be able to recommend someone in your area.anything in south carolina by chance?
Both are great kits with minor differences, you really can't go wrong with either one - we keep both in stock.Hey Tom! I'm just waiting for work to die down before making an appointment with Kevin to come in and get some coilovers on my MYP! But I had a Quick Q. Which would you recommend between the KW v3 and the MPP? I actually took my MYP to the canyons and with only the Eibach springs I had installed it did pretty well. I just feel there is a lot of floatiness which I don't care for. Also what other parts would you recommend if I were to take my car on spirited canyon drives and an occasional autoX/Track day?
Thanks!
Ok great! What other parts would I need besides the MPP coilovers? Rear camber arms?Both are great kits with minor differences, you really can't go wrong with either one - we keep both in stock.
For the enthusiast and aggressive drivers, I would lean towards MPP.
Rear camber arms are recommended to keep alignment specs happy.Ok great! What other parts would I need besides the MPP coilovers? Rear camber arms?
