Vendor ▀▄ eas | Dinan Suspension Components now available for Tesla Model 3
tom @ eas
Global Vendor
Oct 11, 2021
1,245
828
Anaheim, CA
Listings
Founded in 1979, Dinan is well established as North America’s premiere BMW tuner. Dinan develops, manufactures, and markets a comprehensive line of high-performance products and systems, distributed through a nationwide network of Authorized Dinan Performance Centers that includes select BMW Dealerships and Independent BMW Service/High-Performance facilities. Recently, Dinan has further expanded its offerings to include other European marques such as MINI and Mercedes Benz.
Dinan’s industry-leading warranty program, quality products, and solid engineering have helped to make Dinan an almost household word among BMW driving enthusiasts. Road tests conducted by major automotive enthusiast publications over the last 30 years place Dinan enhanced BMWs on a performance level with some of the most exotic sports cars in the world. At the same time, Dinan enhanced BMWs are widely renowned for being civilized and reliable, providing a high-performance BMW-like driving experience without equal. Dinan’s comprehensive warranty program, introduced in 1996 with the cooperation of BMW of North America, provides BMW owners with matching coverage to that offered by BMW’s new car warranty, ensuring that Dinan performance enhancements and the BMW they have been installed in are covered for up to 4 years or 50,000 miles. BMW automobiles can now be performance-tuned without the associated concern of negatively affecting the new car warranty coverage, making the idea of enhanced driving fun and excitement appealing to a rapidly growing number of BMW drivers, and now adding Tesla to the lineup.
Rekudo - Lowering Spring Set - Tesla Model 3​
Add an aggressive stance and appearance to the Tesla AWD Model 3. This spring set lowers the vehicle approximately 1" on both the front and rear, for a lower center of gravity, and improved handing. The progressive spring design provides superior handling, and improved ride quality. These springs have been tested to work with the factory struts.
Features
  • Lowering Springs for Tesla Model 3 – Fits 2018+ AWD (All-Wheel Drive and All-Wheel Drive Performance)
  • High Performance Handling & Reduces/Closes Unsightly Wheel Opening Gap
  • Lowered Center of Gravity – for Better Handling
  • Progressive Spring Design - Slightly Firmer Ride vs. OE - but Good Compromise / Sporty Feel
  • Approximately 1” Lower Ride Height – Closing Up the Fender Gap on Both Front & Rear of Vehicle
  • Complete Set of 4 Coil Springs for Front and Rear of Vehicle
  • Ideal for Use w/ Tesla Factory Struts
  • Black Epoxy Finish - Durable & Looks Great
Rekudo - Adjustable Sway Bar Set - Tesla Model 3​
The REKUDO front and rear anti-roll bar set for your Tesla Model 3 is suitable for street driving, autocross, and track days. The larger diameter 32mm front and 22mm rear bars reduce body roll and stiffen up the suspension. The high durometer polyurethane bushings also improve the performance of the bars since they don't flex as much as factory rubber bushings. The special lubricant reduces squeak and NVH (noise, vibration & harshness) that can be common with non-lubricated poly bushings. Each anti-roll bar has multiple end link attachment options to allow handling adjustments.
Sold in a set of two anti-roll bars - for both the front and rear of the Tesla Model 3. Ideal for use with REKUDO Lowering Springs. Vehicles that didn't come from the factory with a rear sway bar (Base and Standard Plus models) will need Rekudo Sway Bar End Link Set.
Features
  • Fits 2017+ Tesla Model 3 Performance, All-Wheel Drive & Long Range (sub-models)
  • Reduces Body Roll for Improved Handling
  • Includes Matched Anti-Roll Bar Set for Both Front and Rear of Your Tesla
  • Tubular Design – on Both Front & Rear Anti-Roll Bars – Stronger & Lighter than Traditional Solid Steel
  • Front Anti-Roll Bar is 32mm Diameter & 3 position Adjustable (stock front bar is 28mm and non-adjustable)
  • Rear Anti-Roll Bar is 22mm Diameter & 2 Position Adjustable (stock rear bar is 20mm and non-adjustable)
  • Both Front and Rear Anti-Roll Bars are Adjustable from Softest Setting (Reduces Understeer) to Firmest Setting (Reduces Oversteer). End Links are Moved to Different Mounting Holes on the Ends of the Anti-Roll Bars
  • Includes All Installation Hardware – Including High Durometer Polyurethane Bushings, Billet Aluminum Rear Bushing Mounts, and Special Lubricant To Reduce Squeak & NVH (Noise, Vibration & Harshness) That May Be More Noticeable on an Electric Vehicle
  • Black Finish – Looks Great and Prevents Corrosion
  • Ideal for Use w/ REKUDO Lowering Springs
Rekudo - Sway Bar End Link Set - Tesla Model 3​
This rear sway bar end link kit is for vehicles that didn't come from the factory with a rear anti-sway bar (2017-2022 Tesla Model 3 Base, and Standard Plus models). This kit includes the sway bar end link parts needed to install the Rekudo Adjust Sway Bar Kit. These links can also be used as a service replacement parts for the Tesla model 3 (all models with a rear sway bar).
Features
  • Sway bar end link kit includes the parts needed to add a rear sway bar to Tesla model 3 vehicles that didn’t come from the factory with a rear sway bar
  • Includes end links for both sides of the rear sway bar
  • Use with Rekudo Adjust Sway Bar Kit
  • Replaces factory Tesla rear sway bar end links: 1044496-00-E and 1044491-00-E (set of 2 for left and right side of vehicle)
Proforged - Front Sway Bar End Links - Tesla Model 3​
Proforged applied the same technological advancements in ball joint construction to their line of Tie Rod Ends and Sway Bar End Links, delivering a premium product to withstand the rigors of performance car and truck applications. The result is a more durable product that extends the lifespan and maintains the performance level of the steering and suspension system during demanding conditions. Sold as a pair.
Proforged - Rear Sway Bar End Links - Tesla Model 3​
Proforged Tie Rod Ends and Sway Bar End Links are available for nearly every year, make, and model vehicle found on the road today.
Dinan - Valve Stem Caps - Tesla​
Details matter. That's why we've added Dinan Valve Stem Caps to the ever-expanding product lineup! Sold as a set of 4 aluminum caps, each has a Dinan "egg" logo engraved on the face to accentuate even the smallest of details in your high-performance build.
Features
  • Nuanced design for universal visual appeal.
  • Dinan Logo on top
  • Silver, Black & Gunmetal finishes
  • Aluminum construction
Rekudo - Alcantara Steering Wheel - Tesla Model 3/Model Y
The REKUDO steering wheel is beautiful, functional, and easy to install. Choose from carbon fiber with leather grips, or Alcantara wrapped steering wheels.
The motorsport inspired design features deep pocketed palm and thumb grooves on the sides to give you a confidence-inspiring and comfortable grip for your hands. The cross stitched silver threading gives the leather or Alcantara section an extra elegant touch that is only found on high end performance steering wheels. The flat bottom gives you extra room for your legs, and the centerline stripe on RK950-01 makes is easy to find center in street and performance driving applications.
Simply put, we've made personalizing your steering wheel easy. This is our own design. We don't modify or wrap your existing wheel. We ship you a new wheel and you swap over your factory controls and airbag. There's no downtime without your car to ship out and modify your existing wheel, and there are no core fees. Simply swap, install, and enjoy!
Features
  • Direct Replacement in Tesla Model 3 or Model Y with No Core or Downtime Required
  • Choose From Genuine Carbon Fiber with Leather Grips, or Alcantara Wrapped Design
  • Flat Bottom Design with Ergonomically Shaped Finger, Palm & Thumb Grooves - for Driver Comfort
  • Carbon Fiber- Sporty Motorsport Appearance and a Great Look
  • Centerline Stripe - Makes it Easy to Find Center When Driving
  • Silver Colored Stitching - for a Premium Appearance
  • Easy to Install - Factory Controls & Airbag are Reused w/ the New Steering Wheel
  • Steering Wheel is Non-Heated and Fits all models up to 2022 with the Standard Non-Heated Steering Wheel
