miimura
I can understand most service centers not doing PEM repairs, but if the customer doesn't mind the car's downtime, they should offer to repair your PEM at the factory or a specially designated and equipped service center.
I pressed the local SC on the issue with them not opening the PEM for service about a year or so ago. The head of service here is a one of the original Roadster techs (and we're really fortunate and thankful he's here!), so I do grant him a bit of credibility. His statement was that the PEMs aren't designed ESD-wise for the kind of environment that exists in a service center, so cracking one open could precipitate failures down the road.
Coming from an engineering background, I can see this as probably valid, but I also understand that mitigating the risk is just a matter of some training and some small investment in proper ESD equipment (e.g. wrist straps). Given the increasingly difficult parts pipeline, and the decreasing relative density of Roadsters, we're facing an escalation of two opposing forces. Which one will win out is beyond my pay grade.
Contact Gruber before you spend your money.
Tesla Roadster PEM Remanufacturing & Upgrade | eBay
And did they check to see if the cooling hose fell off? The fact that the fan was running and not cooling at all means there was no airflow to the PEM.
I thought I read that he felt the unit and it didn't seem all that hot. So, perhaps the lack of cooling was because the sensor(s) weren't indicating properly? Just saying, when hardware fails, the resulting symptoms can be unpredictable. But, your point about the cooling hose is extremely important. Even if the PEM is indeed toast, cause should be identified. Things don't often fail for no reason, and the chronological proximity to the service event is interesting, if nothing else.
Oh dude don’t leave us hanging! What was the final verdict on cause? And I’m with you man, these cars are something special!
Ha! They did the same on mine when it was replaced. I asked, and they corrected it later (no charge).Sport logo on the PEM means I go faster now, right?!![]()
