1,200 Mile Road Trip to Houston, TX - Am I Crazy?
Discussion in 'Model 3' started by TezTex, Jan 8, 2020.
  1. Rudolf
    Rudolf Model 3 Long Range Dual Motor
    Switzerland
    I find these and other incomprehensible acronyms annoying, too, and I have a feeling that they drive quite a few readers off this forum.
    I know that ICE is used for "internal combustion engine"
    APRP would appear to be the name of an app.
    SOC is a complete mystery to me.
  2. JasonR67
    JasonR67 Member
    Raleigh(ish), North Carolina
    [edit: I see someone beat me to it: Today at 1:47 PM ]
    SOC - State Of Charge
    ABRP - A better routeplanner - A Better Routeplanner
  3. M3tex
    M3tex Member
    Fort worth
    Not crazy, do it! The route is well covered by superchargers, and quite scenic (by my taste).
  4. mikegre
    mikegre Supporting Member
    Florida, Vermont and New York.
    That's funny. I had the same reaction when I saw all those abbreviations. There should be a "Sticky" that has all the explanations.
  5. Rudolf
    Switzerland
    Make a "Sticky" and people will try to outdo each other with inventing all sorts of crazy new acronyms.
    I have another suggestion: if an acronym is not among the top five search results on acronym.com, consider the post to be a troll post and delete it for that reason.
  6. deltajent
    deltajent Member
    Independence, OR
    They're (mostly) not troll posts, just someone who's been around awhile. I too found it annoying at first (BTW so did/does Elon) but it's like that in any specialized field and you come up to speed pretty quickly. For lists of these shortcuts just do a search for "EV Acronym" and you'll find it all. Here's a good place to start: EV Acronyms
  7. Rudolf
    Switzerland
    Thank you. That's useful.
  8. Hugh-SG
    Hugh-SG Member
    Vancovuer, BC
    Thank you for your trip report. ABRP has saved my bacon a few times now, because you can program in Air Temperature, Road Conditions and Winds. You may arrive with more SoC in your battery, but it is better then arriving below 10% and risking battery damage.
    Last summer (August 2019), I let Telsa's Nav system take me from Ritzville, WA to Clu Elum, WA. It told me I would arrive with 29%. I watched in horror this figure slowly crept downward over the next few hours. It was a 26'c day (80'F) and there was a howling headwind.
    I arrived at Clu Elum at 08%. The AC cut out at 20% btw to help extend the range and .... the reason I by passed Ellensberg TSC was the long line up at its five 120kW chargers at the Holiday Inn. I was under the gun to get back home for work next morning so I pushed it and gave my self a good case of range anxiety.
    I now Use ABRP (A Better Route Planner) for all of my trips. I play with temperature ranges so that I have a good look at my options.
    .... and do "top up" before hitting the motel for the night. Your car will use some power to keep the computers and battery from freezing but that is all.
    A car with a Low SoC "may" not have enough juice for it to do a precondition of your battery for Supercharging next morning and you will have a slow charge rate as your battery is Cold.
    Congrats on your 1st major road trip. May you enjoy many more.
    Kindest regards,
    Hugh-SG
  9. MissT
    MissT Member
    Burlington, Ontario, Canada
    We just returned form a 1330 mile trip to Florida and back in our SR+ with snow tires and rims on. (And are now in self isolation :) LOL )
    While we did have some range anxiety as new users on our first long trip it worked out fine. Go for it and learn
