Petra
Knowing Tesla, even that's probably too much to expect...I do suppose it means that they will have a way to disable the stability control from the UI which is a good thing.
No, the Model 3 Performance will be way faster than a P100D. I've already said I think that the Model 3 Performance will clock 1:47 for Laguna Seca. I'm talking about stock cars, I believe that P100D was modified.So you're holding to that they couldn't possible let the Model 3 Performance version outperform the Model S P100D that costs more?
Don't confuse straight-line speed or quickness with track speed. A rwd LR Model 3 is already faster than a P100D around an autocross courseSo you're holding to that they couldn't possible let the Model 3 Performance version outperform the Model S P100D that costs more?
The would be great (even though I'll lose some beers). I agree on the LR but I think it's going to be tough without wider tires and an LSD for the P to get 7 seconds better. I have no idea though since I'm just a bench racer and an autocrosser.From where I sit, I think Randy Pobst might be able to get down to a 1:49 or so with stock (summer) tires on a Model 3 LR RWD. Laguna is a power-friendly track, so its quite possible that Randy Pobst driving a M3P on stock (summer) tires would approach that 1:42 M3 time.
For the S, the first limiter cuts power by 1/2 (to 1/2). The second limiter cuts power another 1/2 (to 1/4). The third limiter cuts power another 1/2 (to 1/8).- Heat built up in battery and moreso inverter and motor. Usually dropping 33% of the power after 1,5 laps already.
An example:For the S, the first limiter cuts power by 1/2 (to 1/2). The second limiter cuts power another 1/2 (to 1/4). The third limiter cuts power another 1/2 (to 1/8).
33% is not in play.
Didn't manage to make it there this year. From the various reports, sounds like it was a lot of fun. Gratz to the winners!2018 ReFuel Awards
Looking at the results....why are there Model 3's in both the Production and GT classes?
I think he did just the front
Correct, fronts only. And I was still getting rear-locking with the stock rear pads so it appears they're fairly aggressive.
How are those Hawk pads on the street? Do they bite well when cold (i.e. normal EV driving won't typically warm up pads on account of regen, you still need panic braking now and then)?
This and how did you find out which size hawk pad fits?
