1.5 Blaupunkt Blowing Fuse
My 1.5 (#278) blows the 15 amp amplifier fuse as soon as I turn the key. Think it was this way when I bought it back in April because it's never had much base. The head unit is a Kenwood KVT-614 with BT module & backup camera, but I think the Blaupunkt is the original subwoofer amp (see below). The PO told me that the stereo upgrade was done by Al & Eds.
I saw some posts saying that the Blaupunkt was prone to failure so is that the likely cause? Anything else obvious that I should check? At a glance the, wires going into the amp looked good.
If the Blaupunkt is dead, is there any consensus on a replacement amp?
Also, if not doing a double din conversion, is there any consensus on the best head unit replacement? I'm OK with a single din with a small screen or maybe a motorized screen that flips down instead of up. I hate that my screen blocks my AC vents in Louisiana.
Just to restate it, I see from this post (Nakamichi CD400 Head Unit swap for the Blaupunkt - Speakers came alive and sound) that the "The harness in the 1.5 is: American International VWH-1004 1987-02 Volkswagen car radio Wiring Harness"
Thanks.
-Brian
Reactions: MCroadster
Short answer is no, but I didn't try too hard.
When I replaced the aftermarket head unit installed by the prior owner, I could see that a lot of the factory wiring had been bypassed (and in some places cut). I'm not even sure the factory amp/sub was still connected. I'd still like to pull the amp at some point and see if I can bring the factory sub back to life, but haven't found the time.
