1.5 Roadster Tire Thread
Discussion in 'Roadster 2008-2012' started by vfx, Jun 23, 2011.
Tags:
  1. backmost
    backmost Member
    Middletown, NY
    Thanks for the info guys, I called the SC in Paramus NJ and they quoted me $68/tire for mount and balance. I'm sure it would be less elsewhere lol.
  2. hmbprius
    hmbprius Supporting Member
    Half Moon Bay CA 94019
    so what is the consensus/final word?
    Michelin Pilot Super Sport on the rear . 225/45 ZR 17?
    Yokohama Advan A052’s ?
    AD07s AD08s?
    are the Toyo Proxes T1R only for 2.5's?
    and other pearl....Only Jack with pads, no lift, and put fear of god/Elon over the head of tire folks just for safety :)
    Hey what about the TPMS...do folks have good luck with those being addressed by local not tesla service center? Thats another confusing thread.....though I see a new updated thread has started so maybe I just need patience and illumination will come ( i do get that 1.5 has different issues than 2.+_)
    TPMS Questions
  3. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Since I occasionally drive in the winter I have the Continental Extereem Sport DWS. They work well. On the 1.5 TPMS is much better as you can just replace the bad unit. Then drive 21 miles to synchronize. No special tools.
  4. backmost
    backmost Member
    Middletown, NY
    Unfortunately the Michelin Pilot Super Sport is no longer available for the size. I couldn't find them anywhere, even online. So I went with the stock Yokohama AD07s on the rear.
    I'm getting them mounted at a local shop for $35/tire. I insisted on a floor jack and no lift.
  5. backmost
    backmost Member
    Middletown, NY
    New tires put in, this was one of the old ones! Down to the wear bar
  6. hmbprius
    Just circling back on the new tire recommendations and also re TPMS...I know there are other threads on this forum but this one is more recent...and hopefully someone can comment.
    I get the TPMS error message when engage to drive, but when in Park, I can still see my tire pressures and temp. Does that make sense? Could it still be the units on the tires causing the issue (that's what local service center said to try first...which seems a bit like guessing not knowing)?
  7. hmbprius
    is this the right michelin pilot sport size..has different lettters after it than earlier in this thread
  8. btown
    btown Member
    Spokane
    My Roadster has been doing the same thing for a year or two. I get a TPMS error at the start of every drive, yet all the tires are properly reporting in their temperatures and pressures. Our service tech theorized perhaps one or more sensors isn't reporting in quickly enough or regularly enough, but that was just a guess. I figure I'll likely try replacing the sensors next time I buy new tires, but who knows when that will be. I don't put a lot of miles on the Roadster anymore now that I have a Model 3 Performance.
  9. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    If you have OVMS, have a look at the TPMS screen on the App, during the start of the drive. That shows individual sensor values, and it is quite easy to see if one wheel or one antenna (front or rear) is bad. We can also have a look at the raw canbus messages themselves to isolate the issue.
  10. gregd
    gregd Active Member
    CM98
    This is an "All Season" tire, which is fine, but be sure you don't mix it with a "Summer" tire on the front wheels. The difference is traction under extreme conditions, and can lead to spins when you don't want them. Unfortunately, I don't think they make them in the size needed for the fronts.
    That said, the prior owner had put them on my car, along with the original Advan tires in the front, and I didn't suffer any issues. But I didn't have any extreme events... They've all been swapped out for the Continental ExtremeContact Sport+ tires, which are the summer variety. Not supposed to run them when temps drop into the 30's or below. (Again, I didn't know this, and regularly drove the car with the Advan tires in the front during the winter. Temps definitely low, but I don't get snow here...)
  11. hcsharp
    hcsharp Active Member
    Vermont
    It's the right size for the rear only, but it's the wrong tire. The Michelin Pilot Sport 4s would be much better but not on a 1.5 because they don't make that tire in the front size, and you don't have the tire learning feature so it's hard to match it with a different tire in the front. Your best bet is to go with Yokohama AD07 all around or better yet Continental Extreme Contact on all 4.
  12. btown
    btown Member
    Spokane
    I do have OVMS, but haven't watched the tire pressures right after key on. I do know I've often checked after the TPMS error/alert message and the tire pressures and temps show fine. Next time I go for a spin I'll start watching the tires before I even turn the key on and try to notice if all the tires come up at the same time or one is slower than the others. I assume that's what you are suggesting I watch for since ultimately they all end up reporting correctly while I'm driving?
  13. markwj
    Hong Kong
    Yes. You should see the individual wheels reporting.
    The other useful thing is to put in a microSD card, and get a can log trace of ID 0x344 on CAN1 (the first can bus), from just before the key is turned until after the first few minutes of a drive. That can show the individual sensors, as they are reported by the car.
  14. chadconway
    chadconway 2008 Roadster 1.5 - VIN 323
    San Francisco CA
    How many miles did you get on your Michelin’s? I only got 10k miles. I’m down to the steel on the inside still have tread on the outside.
  15. drewski
    drewski Supporting Member
    SF Bay Area
    steel on the inside and tread on the outside sounds like an alignment issue?
  16. hanknum
    hanknum Member
    Santa Barbara
    Actually, these Roadsters come from the factory with a lot of negative camber... if you look at the wheels from the front or back of the car, the tops of the wheels are tilted in towards the car. This helps in cornering, but if you do a lot of straight line commuting, then the insides will wear out faster. The cure for this is to corner harder and hit the curves more often :)
  17. dhrivnak
    NE Tennessee
    Actually I had them change the camber so it is only slightly negative. Maybe I lost some cornering if I were to track the car a lot. But for normal driving I get much better tire wear.
  18. drewski
    SF Bay Area
  19. IslandRoadster
    IslandRoadster Red Roadster #609!
    Bainbridge Island, WA
  20. drewski
    SF Bay Area
    guilty, made more obvious since i'm responding in a 1.5 specific thread and I don't even have a 1.5!! :oops:
    • Funny x 2
