10-Way Adjustable Bilstein Suspension Failure
asgard
310
9
Those Bilsteins are crappy shocks but I haven't heard of them dying out so quickly on Roadsters. Yours seems to be the only reported ones on the forum that have failed.
Mark77a
453
176
Poole, Dorset, UK
Mine too ! as above,
Plus: the original UK Roadster sales guy did slip that it was a common complaint with the Sports suspension.
6000 mile on from replacement front adjustable shox, I'm picking up a very, very, slight re-appearance of the same, internal rattle.
Once out of warrantee I may well go for Nitrons, at least on the front.
Also FWIW the numbers on my newer, replacement Bilsteins 10 way shock (LHS .. UK version) is F4-BM3-G622 T0 and spring: Eibach 46/11 A26Coo30H
andybm3
52
23
Bay Area, California
Rob Dietsch at Dietsch Werks can do or set you up with a rebuilder. He also can do the labor if you don't want to do it yourself. Only thing is, which I just found out from looking online, is that he moved from San Jose up to Vacaville :(
Dietsch Werks - 33 Photos - Auto Repair - 1051 Aldridge Rd - Vacaville, CA - Reviews - Menu - Yelp
Bay Area
I'll have to contact him to see if he still has a presence locally, but it appears not.
Another idea for shock rebuilders, this one is up in Sonoma, CA:
Performance Shock, Inc
Pricing of a rebuild roughly speaking should be around $120 / shock.
Also contact Bilstein to see if they have a lifetime warranty. I know some have mentioned some of their shocks do.
Warranty
Wiztecy - my front dampers are starting to leak also, but didn't you go down the Nitron route with Rob? If so how do you like them and how much did it cost?
wiztecy
2,905
563
I love them and have no complaints with about 35k on them now. Nitron recommends to service them something like around 15k miles, but honestly, I feel that's so that they're always performing top notch. Shocks do wear and loose some performance over time but I can't feel any degradation at all. They have the spring perch that allows you to do corner balancing, that's my next investment / setup. These cars are relatively light so having your spring weight dialed in so its balanced on all 4 wheels makes a huge difference in the overall handling and performance of the suspension.
As for the cost I believe I spent around $3900 total with installation from Rob. He had by chance a new set laying around to install on one of his Exige track cars, so the spring rate was heavier, especially in the rear. As I mentioned in an earlier Nitron thread, the driver's side abs/shock mount needs to be slightly modified to accommodate. Otherwise its plug and play.
