100% charge
Discussion in 'Model S: Battery & Charging' started by steilkurve, Jul 9, 2015.
  1. steilkurve
    steilkurve Member
    Montreal, Canada
    Always try to time my car's charge to max level to end right before I leave to avoid letting the battery sit at that level for a long time. Currently on a trip and need to rely on scarce public charging in the area. Charger is available now and I could top up to 100%, but that means it would sit at max for 12 hours. A big deal or not? Thanks in advance for the POVs.
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Charge to what you need with a safety buffer. When I need to charge to 100% I try and not let it sit at that level for any extended period of time.
  3. Electric700
    Electric700 Active Member
    Florida, United States
    You can also schedule a charge so that it completes just before you need to go. When you get to the charging station, just tap the battery symbol at the top-left and set the time you want the charge to start for the scheduled charge. I believe the start time(s) are dependent upon where the car currently is located.
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    Start time and your selected charging amps are indeed saved by location. Oddly, the charge percentage is not and is a "universal" setting no matter where you are.
  5. Electric700
    Thanks, good to know. A dynamic percentage based on location might be nice, but I'd like the ability to turn that feature off in case I need a consistent charge level, say up to 55%.
  6. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    If the charge percentage was location-based, there is a high risk of not charging to the required level if you don't remember what was set at each location. It's best to leave the charge slider universal.
  7. gavine
    gavine Petrol Head turned EV Enthusiast
    Southern New Jersey
    Can you schedule the car at a public charger? Won't the charger session time-out if the car isn't accepting the charge when you start the session?
  8. tga
    tga Supporting Member
    New Hampshire
    Are you implying that the charger is frequently occupied, and you just happened to find it empty? If so, please don't plug in and schedule a future charge; you'd be blocking out other users.
    IMHO, plugging into a public charger without charging is the ultimate EV d*ck-head move; no worse (or better) than parking in a charging space w/out plugging in. Plug in, start charging right away, monitor on the phone app, and unplug and move when done so others get a chance. Don't delay the charging or leave the car there when done.
  9. mknox
    Toronto, ON
    I like to charge to 90% at my office and 70% at home. As it is now, I am always having to go in and adjust the slider every time. It would be a simple matter to add a little icon or something showing the slider percentage on the Charge screen, just like how it shows you the charging amps when it pops open. That way you would always be aware of where it's set. I think as it is now, you could easily forget where it's set anyway unless you pop open the window to check.
  10. AmpedRealtor
    Buckeye, AZ
    I just thought of another option... when we change the charging slider, the car can show us the same indicator that we get when we adjust the suspension height and it saves the location. It puts it in a bubble with an X next to it. We can hit the X if we don't want the location saved, or can leave it and have it remember the charge level at that location.
  11. mknox
    Toronto, ON
    Yeah, that could work.
  12. steilkurve
    steilkurve Member
    Montreal, Canada
    Thanks all. My question was really is 12 hrs at 100% dramatic? That being said, I've since left and only charged to 90%, knowing another public charge was going to be needed anyway before reaching the closest SuperCharger. And that public charge ended up being my mother in law's stove... Or rather stove jack. A nice 40A charge! Better than public at 30A!
  13. mikeg561
    mikeg561 Member
    huntington beach, ca
    Yea, wasn't there a thread that said leaving it at 100% charge for 12-24 hours (once in a while) doesn't really do any harm? Just something you don't want to do all of the time.
  14. Odenator
    Odenator Member
    Olympia, WA
    There is way too much unsubstantiated fear of the 100% charge.
