100D Roadtrip Idea - Entire Natchez Trace on one charge (440 miles), speed limit 50mph
Discussion in 'Model S' started by ratsbew, Feb 18, 2017.
  1. ratsbew
    ratsbew Member
    #1 ratsbew, Feb 18, 2017
    Map of the route
    Speed Limit
    According to plugshare, there are public chargers very near both ends of the Natchez Trace. According to Tesla's website, a 100D can travel 468 miles at 50mph and 70 degrees without climate control.
    This would be a great drive for someone to attempt without charging.
    Bonus points if it can be done 100% with autopilot.
  2. bob_p
    bob_p Active Member
    From a technical standpoint, it may be possible, but probably at a lower speed than 50 MPH. Elevation changes, traffic conditions (maintaining constant speed) and weather (rain, snow, temperature, wind) could also have a significant impact on range.
    You should also assume you'll only use 90-95% of the charge, and not risking damaging the battery pack by depleting it too far.
  3. ratsbew
    ratsbew Member
    I've never driven it, but apparently there is a substantial portion at 40mph which should help increase the range buffer.
    If someone's going to do it, they need to do it before it gets too hot where they need A/C.
  4. WMAC
    WMAC Member
    Nashville, TN
    There are a lot of elevation changes, but, it's a net 1,000 feet change. From Nashville, it's essentially downhill. I've thought about it as I live about 5 miles from the start in Nashville. Would be better to get 10 100D drivers to do it in an AutoPilot convoy and take turns drafting like a bicycle peloton. That would make it a no brainer to get all the way there.
  5. ratsbew
    ratsbew Member
    I love this idea! Make it an event that will get headlines.
  6. TexLaw
    TexLaw Member
    Bellaire, TX
    That would be a beautiful drive! I've driven a great deal of it, and it can be very nice. It's been a good while, but I recall that traffic typically is fairly light and easy to deal with (due to the highly enforced, low speed limit).
    Now, should something go awry, are there any spots along the way where you can bail out for an emergency charge?
  7. ratsbew
    ratsbew Member
    Charging options are sparse. There are chargers just off route in Tupelo, MS which is approximately mid-way, but that defeats the challenge of one charge.
    There are also chargers in Jackson, MS for an emergency top-off (if going north to south).
