100KWh battery pack same design as new Model 3?
Discussion in 'Model S' started by boonedocks, Jul 13, 2017.
Tags:
  1. boonedocks
    boonedocks Active Member
    Gainesville, GA
  2. jaguar36
    jaguar36 Active Member
    NJ
    The 3's batteries will use 2170 cells, not the 18650 of the S. Since the new cells are a significantly different size, the design of the modules will not be the same as that in the S. It probably uses a similar layout and cooling methodology, but beyond that they won't be the same.
  3. Retired
    Retired Member
    Los Altos, California
    What jaguar36 said. But in order to get more cells in the S/X 100kwh packs, there was a redesign of the cooling system which slowed things down but it still uses the 18650 cells like all the other S/X packs.
