Quick correction on the calculation: You mixed ideal capacity and
your capacity ("if 100% is 75kWh"). This only works if 100% is only reported at 75kWh, but the percentage is relative to
your battery's capacity.
If adding 88% added 62kWh, you have very roughly ~70.5kWh
usable 100% capacity. That number from TeslaFi can be confounded in many ways unfortunately, but I'll take it as roughly accurate. At new, I'd expect about 74.3kWh is "usable" at 100% (this would rapidly decline for short time, but not very much).
With a 4.5% of total capacity bottom buffer (seems about right from other data), this means a total capacity of about
73.8kWh on your pack. Again, very roughly, and the number can be wrong in many ways.
Strangely, my total capacity is around 74.5kWh (just 0.7kWh more), but reports
significantly more range at 100% than yours. This is very interesting to me, and I can't currently think of why this would happen. Gonna have to go pull some numbers and see if I am remembering anything wrong, or calculated something wrong. Additionally, the above numbers imply you've only lost
5%, which doesn't correspond to
[email protected]%
at all. Data from TeslaFi could just be a bit off, we're doing a lot of extrapolation here.
