Hi all;
Just picked up my Model 3 LR AWD Dual motor last Thursday. Loving everything about it. I have had issues with home charging on 110 a little sporadically. Today it hit the point where I am concerned....
I will plug in the 110 mobile charger and the white T will just stay illuminated. The dash screen states "charging stopped."
I got concerned that the charge port was broken or faulty, so I took it to a level 2 charger (thankfully ~100 ft away) and it worked no problem (though at one point it did say charging was interrupted on the app but it seemed to still be charging when I went out to check on it).
At this point given that the level 2 charger (chargepoint w/ adapter) worked, I am assuming the mobile charger was just dead/faulty to begin with... and maybe today it finally crapped out? I have successfully been able to keep it plugged in with 5 miles/hr charging overnight, but it has been a struggle to get it to "start charging" with a green T. Today I can't get it to charge at all.
Thoughts? Faulty connector/mobile 110 wand? or is charge port screwed?
