110 outlet in Model 3
Discussion in 'Model 3' started by davek, May 14, 2016.
Tags:
  1. davek
    davek New Member
    Walcott, Iowa
    I would like to pull into a RV Park and plug into a 14-50 outlet and then be able to plug into 110 outlet inside the car to be able to use a CPAP machine and sleep in the car.
    It could be part of a camping package.
  2. JeffK
    JeffK Well-Known Member
    Indianapolis
    There's nothing stopping you from buying an inverter for any car you own...:)
    They're about $25-30 and up
  3. davek
    davek New Member
    Walcott, Iowa
    That's good to know. Thanks
    Now is there any chance of some sort of camping package that will run the climate control and keep lights off etc.
  4. wdolson
    wdolson Active Member
    Clark Co, WA
    In the Model S and X you can run the climate control when the car is off. Some people have made signs to put in the window on hot days when they leave and animal in the car explaining that the A/C is on and the animal is in no distress.
    Bjorn Nyland, who has a lot of videos on YouTube on his channel TeslaBjorn camps in his car frequently, though he does live in Norway. He also has a thread in the videos section of this forum. If you have any questions about the logistics of camping in a Tesla, he can probably answer them.
  5. TaoJones
    TaoJones Beyond Driven
    The Americas
    Consider the following approach:
    Hardwire a 12V receptacle under the passenger seat into the mid-cabin area.
    Acquire a 12V adapter from the CPAP manufacturer.
    Connect the CPAP as needed.
    No loss due to DC-AC conversion.
    No headaches with switched 12V as from the console.
    No need to fiddle with camping mode adjustments.
    This works for any 12V appliance, including the infamous crockpot and popcorn maker*, so it should work fine for a CPAP, presuming the manufacturer will sell you a 12V adapter.
    * Do not buy/try either a 12V crockpot or a 12V popcorn maker. Trust me. Might as well buy a 12V microwave. Yep, they make those too.
  6. davek
    davek New Member
    Walcott, Iowa
    I guess you need you need a 110 volt pure sine wave inverter hooked to a 12 volt battery in order to run the humidifier in a CPAP. At least you will never run out of battery.
  7. StaticDischarge
    StaticDischarge Totally Unknown....
    Edmonds, WA
    RV park power often includes 110V along with the 240V 50A or 30A. Use an extension cord thru the car window/door?
