Solarman004
@Enz295 , Here is another technique to try. You most likely have 15 amp circuits in the garage. Before plugging in, set the car to charge at 9 amps max. Then plug in. If your GFI doesn't trip after a few minutes, go to 10 amps. Keep doing this until you reach 12 amps, then stop. The maximum continuous current shouldn't exceed 80 percent of the breaker rating. That would be 12 amps for a 15 amp circuit.by clicking out I mean what Solarman said. The GFI socket pops. All I have are GFI sockets in the garage. And I confirmed I have the correct wiring by buying the circuit checker.
So I am therefore not able to charge using the 110V provided cable?
My intention was not really to charge since I have a Level 2 charger in the garage. It was more to leave the car plugged in during long periods when I travel out of the country. This seems ideal to maintain a 50% charge to me.
If the GFI trips at sat 11 amps, just set your car to charge at 10 amps. This will be slow charging, and you won't be able to pre-heat, but it will work. I've had to do this when staying at an old house and using a long, undersize extension cord. I maxed out at 9 amps, but it worked.
