smac,
In this topic I see a lot of confusion between rated range and typical range. This is mainly because when you say 171 miles typical range, people compare this to 171 miles EPA rated range. These are two different measurement systems Tesla uses in different locations. Because you are from the UK, your car doesn't display (can't display) EPA rated range. Similarly, Model S cars in North America can't display typical range. Your S60 is comparable to other S60's from Europe but not from North America. Merijn's battery survey has many S60 entries from Europe. Your car is comparable to those. With 171 mi typical range (275 km typical range), your range is similar to other S60's. It is not the lowest. Your range loss is about 5%. I recommend switching to km instead miles when you read range numbers at 100% charge. This way you can avoid a lot of confusion and find a lot more comparable data in this forum.
171 miles typical range in Europe = 198 miles EPA rated range in North America
