12 V battery pictures
Discussion in 'Model S: Battery & Charging' started by ddruz, Sep 25, 2012.
  1. ddruz
    ddruz Member
    North Shore Oahu, HI
    There have been some questions about where the 12V battery is. Here are three pictures that I believe were posted elsewhere on this site some time ago. I cannot remember which thread or to whom to give credit. I hope the person who took them does not mind that they are reposted here. Any other pictures people have of the 12V battery would be appreciated.
  2. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    Could you see what size and brand it was?
    How accessible for changing it out (by owner) is it?
  3. Seegem
    Seegem Member
    New York City
    Can someone tell me what this battery is for? The electronics, as a backup, or main powersource for the electronics? Thanks, Mark.
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    Also, it looks like a sealed lead acid battery as opposed to the typical flooded cell automotive battery. Is that the case?
  5. strider
    strider Active Member
    NE Oklahoma
    It maintains power for critical systems in the event the main battery is damaged/disabled like in an accident. It powers hazard lights, airbags, door lock/unlock, etc. In the Roadster it's also what listens for the key fob to unlock the doors and powers the 3G connection for remote access whenever the car is powered down.
  6. dadaleus
    dadaleus 4GETOIL P85#S70,FdrX,S85D
    Solana Beach, California, United States
    I've been asking lots of questions about this, so this is great info. I noticed that the 12v outlet and USB outlets in my Model S never turn off, even if I press the "Power Off" button on the display. I was worried if this was going to kill a 12v battery since I was leaving my USB key (which has an LED on it) and cell phone plugged into it at night. Hadn't gotten clear answers but looks like this is what it's connected to.
  7. doug
    doug Administrator / Head Moderator
    SF Bay Area
    Those are my photos. I'm just curious where you found them.
    You can see them on Flickr (and at higher resolution) here: http://www.flickr.com/photos/[email protected]/6203996807/in/set-72157627678175337/
  8. ddruz
    ddruz Member
  9. Ceilidh
    Ceilidh Member
    Los Gatos/Santa Cruz Mountains/Silicon Valley, CA
    Has anyone yet been able to get the size (physical dimensions ) and specs (output/capacity, etc) for the 12 V battery that comes with the Model S? I know that Optima is now making a battery designed for the Prius. Wondering if their yellow tops would offer any advantages for a Model S?
    Any specs or input would be welcome.
    Cheers.
  10. jerry33
    Texas
    The design for the Prius amounts to changing the terminals to JIS standard from SAE (JIS has smaller diameter terminals). There is nothing else Prius specific that I'm aware of. Also Optima doesn't have the best reputation since they changed owners and switched production to Mexico. I'd look at Odyssey batteries, they have a better quality reputation.
  11. W.Petefish
    W.Petefish Active Member
    I was thinking something similar. But considering the hassle to actually get to the battery, don't bother. (ask TM service)
    Besides there are remote charging lugs mounted somewhere... (don't even ask me!)
  12. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    My experience with Optima is that they fail rapidly when deep cycled. Not the best IMO.
  13. Ceilidh
    Ceilidh Member
    Thanks for the tip! Now I just need to figure out which one fits...
  14. W.Petefish
    Give ya a hint: NONE OF THE ABOVE!
    At least judging from the size and location. (even that has changed from the beta cars.)
  15. pilotSteve
    pilotSteve Active Member
    Prescott Az
    Hey, if the 12V battery fails it should be replaced for no charge under the (sort of required) annual or prepaid maintenance plan. I'm not worried about finding a replacement myself, I'll just have Tesla take care of it!
  16. artsci
    artsci Sponsor
    Timonium, Maryland
    I've had very bad experiences with Optima batteries.
  17. KJennerator
    KJennerator Member
    MA
    Do yourself a favor and never ever by an options battery. Go so by your local Batteries Plus Bulbs store and pickup an X2 Power or Odyssey battery. There is a reason that they no longer carry optima in store.
    - - - Updated - - -
    Excuse me. Optima not options. Autocorrect :/
  18. jerry33
    Texas
    Optima sold out and the new owners moved the production to Mexico. Outsourcing: fewer jobs, lower quality.
  19. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    I was also going to ask about just using a Yellow Top. I have one in my 2009 Tahoe, and 5 years later it still works just fine. the OEM one (replaced twice) couldn't power the radio while I washed/dryed the vehicle. and would result in a nostart after an hour or two of music. The yellow top will run the radio (sat nav) all damn day, then start right up!
    I'm still saving my pennies for an S though...
  20. glhs272
    glhs272 Unnamed plug faced villian
    Burlington, WI
    I have had very good luck with optimas. I have them in all of my ICE vehicles (2 diesel trucks). They have been working reliably for many years, keeping the trucks starting even in the dead of winter. Just don't let them run dead. If you do, you have to blast them with a high power 12volt booster/charger to get them to take a charge again.
