Not happy with purchase. I got one of the recommended models:
https://www.amazon.com/gp/product/B...sin_title_o01_s00?ie=UTF8&psc=1&tag=tmc064-20
Looks and feels a little cheap when you unbox it but the price was cheap also. It is compact and even came with a little bag for storage however the nozzle is
HORRIBLE!
It is a screw on nozzle and it provides a secure fit but after tire is inflated you end up losing air pressure because it takes to long to unscrew it. Prefer the snap on and snap of caps which has minimal loss of air pressure when you're done with inflation. The other problem is the digital pressure reader is not very accurate. Seems to measure higher than what it actually is.
I use a Rhino heavy duty tire pressure gauge to check it and it is substantially lower than what the EPAuto 12V pump indicated.
I measure the PSI before and after using the pump and it has a reading that is 5 to 7 psi difference. I also compared it to the Tesla read out
which is fairly close to the Rhino tire gauge.
Anyway gave this pump away to the neighbor teen for his bike and basketball. Back in the hunt fir an Air Compressor that won't blow the Tesla fuse. This time more specifics with a better nozzle.
