Evoforce
Link?
It is actually spelled Battmobile. Did some checking and they are now called Element 3 Batteries. A previous poster had posted about this same battery. I didn't know there was name change.
Link?
Where I am, winter temperatures would likely kill an unmanaged lithium battery. I don't think it's a one-size-fits-all solution!
A lot of ICE cars now come with similarly unmanaged Li-ion batteries for their 12V. My last car, a 2015 BMW M3, had one and it was not temperature controlled.
precisely correctKeep in mind if swapping batteries, Tesla has at least a couple different generations of 12v batteries now and needs to change parameters in the car settings as to which type is installed. Probably changes the way the 12v charging happens depending on battery characteristics.
So maybe inquire if you're dropping some non Tesla battery into the car, or doing the change out yourself and notice that it's not an identical part number going back in.
yea, the battery and installation is fully covered under warranty. If out of warranty, the price can vary a lot, but the aver will be between $150 and $250. It takes about an hour because there are a lot of buttons that need to be removed in the Frunk to take out the tray and access the battery. Better have Tesla do it as sometimes the car has to be told what kind of battery you have so the charging system will know how to handle it.What's the cost of the 12v outside of warranty? Is the 12v even covered by warranty?
I just replaced my 12 volt battery in my 2013 P85 with the element 3 LiFePO4 battery. It was definitely not easy in the early generation cars... took about 3 hours, but that includes time to go hunting for bolts dropped. The price Tesla wanted for their OEM replacement was around $220, which is much higher than the prices quoted just a couple of months ago in this thread.
My 12 volt was replaced under warranty in August 2014 due to a traction battery failure... the contactor failure common to all early packs. Anyways, once the traction battery goes, they replace the 12 volt since it then deep cycles and I didn’t have a deep cycle battery until the replacement. That battery lasted for 3.5 years. The car is kept in a garage, so I am not as worried about the LiFePO4 battery as it normally won’t be subject to freezing temps.
why would you spend over $400 to replace it yourself when tesla SC will do it for you at half the cost?
not trying to be an ass.. genuinely curious
Maybe a dumb question... but can the battery swap be done like in an ICE? That is, disconnect, remove, replace, reconnect? Or is there a requirement to maintain 12 volts to the car at all times? I recall having to re-enter security codes into the stereo units...
Mine took forever to boot this morning and the center screen didn't come to life on its own...I did the steering wheel button reboot and eventually it came to life also. I'm not scheduled for service for two weeks and I need to drive several hours to get there. Failure is not an option... I'm getting nervous that my battery is failing faster than they might have expected.
