12v always on after sentry mode update?
PoitNarf
My dog's breath smells like dog food
Jun 7, 2016
2,870
4,011
NJ
I’ve seen others mention this as well. I don’t believe there is a way to turn the 12V outlet off when Sentry Mode is enabled. Do you have something plugged in that’s draining power while your car is parked?
crackers8199
1,285
599
lake elsinore, ca
I don't have sentry mode on, and even still the 12v seems active. I have my XM onyx plus plugged in and until this update (which I just got today) it always turned off when I left the car...now it stays on.
ewoodrick
5,285
3,735
Buford, GA
It's supposedly a new feature that was announced a little while back. I'm not really a fan, too many opportunities to kill a 12V battery.
I'd rather have some options, like on or off, and maybe even an on for X minutes. Also a different setting for USB ports would be nice.
Reactions: crackers8199
crackers8199
1,285
599
lake elsinore, ca
yeah, making it configurable would really be the best of both worlds. as it is, i can already see this killing my battery when i leave my xm unit on (because in the 7 months i've had the car i've already conditioned myself that it will turn itself off)...i'm trying to remind myself to turn it off when i leave the car, but i'm sure i will forget at some point.
Pkmmte
Le meow
Sep 19, 2017
694
1,181
Los Angeles, California
I personally love this change. I used to have to leave my door/trunk somewhat open before just so the car can stay on and charge the dashcam sometimes. Now I can leave it locked without worrying that it'll cut the 12V power.
crackers8199
1,285
599
lake elsinore, ca
yeah, this is a huge problem. it definitely doesn't time out - i parked in my garage almost an hour ago and just went out to double-check...it's still on. does anyone know if there's an alternate 12v source that is still switched when the driver leaves the car?
Garlan Garner
Banned
Mar 31, 2016
11,351
6,064
Chicagoland
Yes...I know of at least 2 of them. I'm using them....such as the door pocket lights still extinguish when the driver leaves.
The footwell lights still extinguish when the driver leaves the car.
sreams
732
1,260
Sacramento, CA
I know you got used to how it worked before... but I've owned several cars where the 12V plug worked with the car off, and I preferred it. Most people installing XM or other audio sources find a swtiched 12V supply, and don't use the 12V plug (regardless of what car we are talking about).
crackers8199
1,285
599
lake elsinore, ca
that's not the point, the point is that they changed how it currently works without telling anyone. if anyone has something plugged in that they have tucked into the cubby under the armrest, they have no way of knowing right now that the outlet is always on rather than turning off when exiting the car like it previously worked.
also, i wouldn't say "most" people installing something as simple as a portable XM unit find a switched 12v source...a more involved audio setup, sure - but these units are designed to plug into the 12v socket by default. not to mention that until this update, that socket WAS a switched 12v source.
Reactions: Garlan Garner
sreams
732
1,260
Sacramento, CA
Fair enough. So the huge problem is the communication. Not the actual change. The previous behavior seemed like an oversight/bug to me compared to other cars I've owned.
Maybe contact Tesla and suggest they add this to the release notes (if it isn't already there). Of course... now you do know, so the huge problem doesn't exist in your particular case.
Reactions: Pkmmte
crackers8199
1,285
599
lake elsinore, ca
yes and no. i still have to get myself used to turning the damn thing off when i exit the car now...which isn't a huge deal, but like anything when you're conditioned to it working one way for the 7+ months i've had the car, i'm bound to forget once or twice or a few times until i get used to it. i just hope that doesn't end up draining my battery when i need it.
i think the best way for them to handle it would be to make it a configurable option, or even allow you to toggle the power on the 12v socket from the app...that would seem to keep everyone happy.
Reactions: MikkoJ and 03DSG
sreams
732
1,260
Sacramento, CA
You don't have to do that. Just wire it up the same way you would in any other car that has always-on 12V plugs. Find a switched source. Somebody replied earlier that some of the wiring for interior lighting might work.
crackers8199
1,285
599
lake elsinore, ca
yes, i plan to do that...until they change that to always on as well lol
either way, it's not going to happen until next weekend as i already have a road trip planned this weekend...which is what i was getting at when i said hope i don't forget to turn it off and have it drain my battery when i need it.
