12v battery issue, Tesla horrific response
Discussion in 'Model 3' started by Tjhappel, Sep 19, 2020.
  1. vogz
    vogz Member
    Batavia, IL
    No they won’t. Just searched on Advance Auto Parts website and they offer 3 different 12V batteries for the Model 3.
  2. vogz
    vogz Member
    Batavia, IL
    Couldn’t agree more.
  3. Daniel in SD
    Daniel in SD Well-Known Member
    San Diego
    When I search they list three batteries of different sizes, all wrong. o_O
    Seems worse than just listing no batteries TBH. I think something is screwed up with their database.
  4. Phlier
    Phlier Bluebird
    Utah
    I might do that when mine goes bad... I cast my own bullets for hand loading ammunition, and lead-acid batteries can be a good source of lead for casting, but it's also a pain to do it safely.
  5. vogz
    vogz Member
    Batavia, IL
    I apologize, I didn't have time to investigate the battery options to see if they were the right size.
    I'm sure most auto parts stores would have a 12V battery with similar dimensions available in a pinch though. It's not rocket science and could get you back on the road until you were able to source a proper replacement.
  6. Daniel in SD
    San Diego
    Yes. Apparently a 51R battery will fit. And if you're calling AAA just tell them you have a Nissan Leaf. :p
  7. SageBrush
    SageBrush 2020: Drain the Sewer
    New Mexico
    Speaking of the devil, I bought a 51r interstate branded 12v from walmart a couple of years ago for our LEAF and it is still doing fine even though I don't think it is a deep cycle battery. Perhaps it knows that it has a 5 year warranty ;)
  8. alstoralset
    alstoralset Man from another place
    Pacific Northwest
    Has anyone tried desulfating one of these failing batteries?
    I've had good luck desulfating a few batteries that have failed to the point that they won't hold a charge. After a couple of weeks of desulfating with the unit below, they become operational again.
    It would be scary to desulfate a Tesla battery in situ, so this would probably be something you do with your first battery after getting a replacement, unless you can pull the battery and not drive the car for an extended period.
    https://www.amazon.com/gp/product/B00D7HZ6FC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  9. Blue Express
    Blue Express Member
    Long Island, NY
  10. Margaritaboy
    Margaritaboy Member
    Northern California
    Yeah, not a big deal to just replace it. Not different than an ICE vehicle.
    I walked into NAPA auto parts with the dead battery, they had a replacement in stock. Period.
    took me about 4 minutes.
  11. Daniel in SD
    San Diego
  12. Daniel in SD
    San Diego
    Yep. As long as you ask for a 51R or get someone willing to measure the size you’ll be fine. I don’t think the Model 3 is in their database since they don’t sell the “exact” battery.
  13. smatthew
    smatthew Active Member
    CA Bay Area
    I don't think a desulfator isn't going to help most failing batteries we hear about here. If the battery was just having difficulty holding a charge, that would be when you get a nice error message and have a fair amount of time to deal with it. But most failures we hear about appear to be shorted cells and corroded plates.
    Plus batteries only get sulfated when they're constantly undercharged. Not really what's going on with a Tesla.
    However, if you already have a desulfator, give it a try on your old battery after you get a new one and let us know!
  14. SageBrush
    New Mexico
    What about front/back positioning of the posts ?
    From pictures I get the impression that it is not standardized. My recollection (don't take my word for it !!) from the last time I looked at the Model 3 battery is that the positive terminal is to the left and back of the battery but that the terminals may be long enough to also attach to posts in the front
  15. beachsideev
    beachsideev Member
    usa
    that is what the "R" in 51R is for. Right positive terminal. It installs backwards.
  16. SageBrush
    New Mexico
    Does that mean that all 12v batteries are oriented for labeling with the posts in the front ?
  17. beachsideev
    beachsideev Member
    usa
    That is supposed to be the way it works. I can't that it is 100% true but it has been in my experience.
  18. RayK
    RayK Active Member
    San Jose, CA
    It's not really "front" vs. "back". It's the positioning of the positive terminal with respect to the long edge of the battery closest to it. Most 12V batteries will have their terminals closest to one edge than the opposite side. When a battery of a particular physical size and CCA rating is available in two group versions, the non-R (sometimes it's an F) battery will have the positive terminal on the LEFT, whereas the R (or F) battery will have the positive terminal on the RIGHT. This can be seen in the chart here:
    BCI
    Column title BCI is the group number for the battery, while Polarity is stated as L/H-POS for left hand positive or R/H-POS for right hand positive. Examples are 21 vs 21R, 24 vs 24F, 27 vs 27F and 34 vs. 34R.
  19. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    Despite my best efforts of testing & monitor (IR) my 12v , I had a 12v battery failure during an OTA update while on a road trip. 2020.40.3 was successfully installed on 1000s of cars so I was confident ... famous last words.
    The article I found and mentioned in the below thread shows Tesla is following common guidelines for maintaining the 12v as far as I can tell via empirical evidence I see.
    I monitored the 12v battery voltage during an OTA update
  20. Daniel in SD
    San Diego
    Yeah, don't do that. I only do OTA updates with the car in my driveway with another functional car next to it. :p
    I wonder if the problem is that Tesla got a bunch of bad batteries from the supplier. It sounds like the failure mode is not typical capacity degradation so they're have trouble detecting it.
