AlanSubie4Life
Efficiency Obsessed Member
So I honestly suspect that maybe half the car's existent life is spent in sleep, while the other half is spent awake, per hour-by-hour basis.
Tesla says that 1% per day (0.955*0.01*76kWh = 725Wh) is normal for vampire drain.
We know that idle mode is over 100W; let's say it is 150W for the sake of argument - we know this is not far off based on the charging efficiency vs. charge rate curve. I've seen multiple people state about 7W-10W for sleep mode (by monitoring 12V battery current).
We know that many people can hit the typical less than 3 rated miles per day of vampire drain. So 725Wh per 24 hour period, or less.
You can piece these pieces together and come up with reasonable scenarios:
You can't have more than 5 hours of time in idle to come in under 725Wh. That puts an upper limit on idle time for a well-behaving car. The rest of the time, 19 hours or so, is spent in sleep. 19 hours * 7W = 133Wh.
This results in about 3 wake ups a day for people to top off the 12V. I've seen a lot of TeslaFi data suggesting that's a decent approximation for a typical day.
The formula is (roughly):
7W*(x) + 150W*(24-x) = Vampire Energy (per day)
Or, x = ( 3.6kWh - Vampire Energy ) / 143W hours per day sleeping.
So, I suspect most cars spend most of their time sleeping.
