CertLive
Do you have some actual numbers on “the amount of 12V battery replacement complaints” other than just perusing this forum? If so please share, because I haven’t seen any actual data on the topic. We know roughly 500k Model 3s have been sold (at least that’s the number I’m pulling out of memory from an InsideEVs article I read a month or two ago, and I’m 48 so the memory isn’t what it used to be) so if you have hard data on early 12V failures we can calculate the early failure rate. Then all we need is early 12V failure rate for the average car and we can compare the two in order to determine if this is really an issue worthy of over 300 posts to this thread or if this is typical.
Well it seems there is some sort of issue here and it also seems that 2 years for a 12v battery to die is quite bizarre. So in that light compared to other cars on the road its an early failure. Unless its a very cheaply made battery with a bad reputation? Not all is created equal but 2 years is not good enough. 300 posts is quite a large and well thought out issue. Look at brilliant investigation going on by engineers. Good luck getting the real 12v failure rate figures but if its 1 or 90,000 cars it is not good enough. Not if you compare it to ice EV will replace. Even saw a video yesterday of the new VW ID 3 lose its battery power after 5000 miles.
