1129182-00-B - ASY,12V BATT AND VENT PLUG,M3So it seems best to buy a replacement battery and have it on hand if you own an early Model 3. Which battery is the stock replacement?
Sounds great! I’ll be doing the same if/when my 12V bites the dust. On another note can you weigh the Tesla 12V AGM battery? Curious what the weight difference is between that and the 11 lb. Ohmmu.
Ski
Just had a chance to weigh my dead AGM out of Telsa. Came back at 30 lbs. 19 lbs saved. But sound system enhancement and hopefully more longevity is real reason I replaced with Ohmmu. Installed for 3 weeks now with impressive performance.
Also I talked to a Tesla Service Rep today about replacing my broken battery. Since I took it out of the car, they will not warranty replace the battery. They will recycle it for me, though. I may ask again next time I am in since when I went to request a service appt via app they quoted 3 weeks to replace battery. I ordered Ohmmu cross country and installed in 5 days.
This probably has a lot to do where you're at. I was quoted 3 weeks to replace mine. They were scheduled to come out on 7/30 but asked if they would come sooner. They bumped me up and they (mobile unit) were here yesterday (week sooner). 3 weeks without a car is too long. 2 was hard enough. Great to be back in business. They replaced it under warranty with the same exact battery. Mobile guy said they last between 2-5 years. I got 2.So I guess in retrospect the thing to do is get them to replace it under warranty...then pull the replacement out as a backup and throw the Ohmmu in. On another note.....has anyone gotten a Mobile Ranger to replace the OEM battery quickly or quicker than a SC? I’m sure they ‘May’ have a few in stock a Ranger can install sooner? (I know wishful thinking)!
Ski
I had Tesla Mobile Service replace mine in my garage. Unfortunately I had to pay $129 (~ 56k miles on the car, close to 2 years old). I had them do it because I had to travel and needed it done when I got back. The guy told my wife that Tesla discourages owners from doing it themselves because of having to disconnect a hi-power line (?)So I guess in retrospect the thing to do is get them to replace it under warranty...then pull the replacement out as a backup and throw the Ohmmu in. On another note.....has anyone gotten a Mobile Ranger to replace the OEM battery quickly or quicker than a SC? I’m sure they ‘May’ have a few in stock a Ranger can install sooner? (I know wishful thinking)!
Ski
I watched the service guy swap out batteries. Let's just say, so simple a caveman could do it. Honest!I had Tesla Mobile Service replace mine in my garage. Unfortunately I had to pay $129 (~ 56k miles on the car, close to 2 years old). I had them do it because I had to travel and needed it done when I got back. The guy told my wife that Tesla discourages owners from doing it themselves because of having to disconnect a hi-power line (?)
Didn't even do that. Pulled off the Pos first! Everything else says Neg first. Oh well, it all works.Just had to replace my 2018 RWD battery after it died as well. They disconnect the high voltage from a connection under the backseat.
This looks like a great procedure, and I have no reason to doubt it. But how much of this is theory, and how much have you actually attempted (or can otherwise confirm)? The tea leaves say this is something I'll probably need to do in the next year or two.If my 12V AGM battery failed, I would do the following. Open the frunk using the 9V battery I carry in my pocket anytime I drive my M3. Note, the frunk will not open if the 12V battery has not failed (new security feature recently added). Using the 10MM wrench I leave in my frunk remove the negative terminal from the 12V battery post, this essentially removes the 12V battery. Connect a jumpstarter or jumper cables from another car to the positive post on the 12V battery and the removed negative cable (NOT the negative post). Remove the jumpstarter or jumper cables as soon as you hear the contactors close. A few seconds later the 12V DC-to-DC converter should activate and the car should fully wake up and operator normally. At this point you will see an error on the center display indicating the 12V battery has a problem which it does because the negative side is disconnected. Even though the 12V is not connected the car is fully functional and and can be driven. If the tow truck has ramps, the car could be driven onto the tow truck (no need for tow mode which disables after 20 minutes). If the car goes to sleep with the negative cable disconnected, you would need to repeat the steps as described above. I like disconnecting the 12V battery because it could have shorted cell(s) which could impede jumping in parallel or cause the car to sense a problem and shut down the 12V DC-to-DC converter which would disable the car. All of the above assumes that ONLY the 12V AGM battery has failed in some way it does not account for other possible problems (ie.. failed DC-to-DC converter etc....).
My 2018 Model 3 LR with 10k miles just had a 12v battery failure and it had to be towed to Tesla. It was so dead that Tesla couldn't confirm the issue remotely and therefore could not dispatch the mobile service vehicle. The car was parked in the driveway so the tow truck operator had get it in towing mode by attaching a battery device to wires behind the tow hook cover then opening the frunk to get his battery attached to the car battery. It worked for awhile but eventually towing mode stopped right at the flatbed ramp. So we attached my 12 amp battery charger to the car battery but that didn't work either so he dragged the car the rest of the way onto the flatbed with the help of liquid dish washing soap. Oh, then the right hand front window went down so we had to cover it with a trash bag using 200 mph racer tape I had on hand. (I used to race cars) I needed to do this because I live in Florida and we have showers this time of the year. The car was getting towed to Tesla's new service center in Fort Myers which is only 30 miles away. Otherwise it would have to go 105 miles to the east coast or the the same distance to Sarasota. What a pain the rear end. I have a 2017 Model S 100D with 12k miles and I'm wondering if I should change the 12v battery to be safe. Any thoughts please.
