12v battery
Discussion in 'Model S: Battery & Charging' started by P85DBeast, Apr 1, 2015.
  1. P85DBeast
    P85DBeast Side tEsLa
    Atlanta, GA
    as anybody's 12v batter pack failed yet becuase mines hasn't I just want to know the symptoms before it happens becuase I drive a lot and don't want to be parked somewhere waiting for tesla service tow truck to arrive just asking I really want to know!!!!
  2. spaceballs
    spaceballs Member
    Sammamish
    if your that worried, just buy an small battery jump starer and keep in in the frunk.
  3. FatSal
    FatSal Member
    Cleveland, OH
    Tesla actually called me and said they had been monitoring my car and noticed signs that the battery would need to be replaced soon. They said to schedule an appointment and I could continue driving the car. About 1 week later I received a notification in the car to replace the battery soon. I replaced the battery about 3 days later. Never had any other issues.
  4. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    The car is supposed to give you an alert if the battery is close to needing replacement.
    Prior to receiving the alert, I noticed the car didn't sleep much. It seemed to be awake more than it was asleep. The car wakes itself up to top off the 12v battery. If the 12v is not holding charge well, the car will be waking up more often to charge it. That is your first indication that something may be afoot.
  5. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    Tesla changed the way the car monitors the health of the 12V battery about a year ago. The car now shows a warning as soon as there is concern about the health of your 12V battery.
  6. jepicken
    jepicken VIN: 80322
    Chandler, AZ
    Pardon the dumb question, but how can you tell how much the car is sleeping?
  7. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    I hate it when my car can't sleep. ;) It's up all night pacing the garage.
  8. apacheguy
    apacheguy S Sig #255
    So Cal
    Everyone has their favorite method. I use my own code to monitor range and SOC in 30 min increments:
    Web Based Model S Interface
  9. brianman
    brianman Burrito Founder
    Yah, the tire wear is killer.
  10. woof
    woof Fluffy Member
    Mine snores.
  11. sorka
    sorka Well-Known Member
    Merced, CA
    Everyone is going to need to replace their battery frequently. If you leave the car in always connected mode, the battery will be half way drained 6 times a day and recharged six times a day by the inverter when it's just sitting there whether it's plugged into shore power or not.
    Lead acid batteries due to not tolerate constantly being discharged.
  12. dirkhh
    Portland, OR, USA
    I'm curious about "6 times a day". It appears that the 12V battery is a meager 35Ah unit, so 420Wh capacity, trying to keep it healthy by only half-cycling it would give us 210Wh usable. Your assumption of 6 cycles a day means you assume the car is consuming about 1.2kWh a day for the connected mode or 50W. Given that a typical phone can stay connected on less than 2W (and usually on even less than that) I'm not quite sure why you assume a 50W load.
    I'm not saying you are wrong, I'm just curious how you got there.
  13. mibaro2
    mibaro2 Member
    Georgetown, ON
    And it is strange that Tesla encourages you to have "always stay connected" checked, and energy savings off. Whenever I take my car to the SC, they switch it to be like that. I use to switch it back, but now appreciate the car waking more quickly.
    But back to the 12v getting drained more often with always connected checked...why would Tesla encourage this if it will cause the 12v battery to die more frequently?
    I also wonder how the cold affects the 12v battery...maybe I should get mine replaced after the winter we had ( or are still having..it is snowing right now !). It was a bitterly cold winter.
  14. AmpedRealtor
    Buckeye, AZ
    When I launch VisibleTesla, it tells me if the car is sleeping and requires a confirmation to wake it up. Prior to replacing the 12v, more times than not, when I checked on the car using VisibleTesla the car was not asleep and the application logged-in immediately. After replacing the 12v, checking on the car regularly using VisibleTesla results in the "car is asleep" message 90% of the time.
  15. Steve Watkins
    Steve Watkins Member
    United States
    failed without warning day before yesterday; usually will either get warning or call from Tesla that it is about to go out; last time went out while using "loaner" pack while my battery pack being "reconditioned" Jan. 24, 2015; 68,900 miles (approx.) currently; no explanation so far; WARNING: if using loaner pack, rated range is not accurate until pack has been cycled through a few times (I was told) but I have not tested it out since car dying with 11 miles rated range 3.5 hours from home
