12V issue and "isolation"
cpa
3,809
5,909
Central Valley
Well, I got the dread "12V error warning" earlier today as I got back into my car to return home from the grocery store. It cautioned me that my car may not restart. It took a few moments, but I was able to put the shift lever in drive, and I made it home.
I telephoned roadside assistance, and they told me that Seaside Service Center would be contacting me no later than Monday.
The service manager from Seaside called me about 45 minutes later. I inquired if the ranger could just come to Fresno when convenient next week to replace the 12V. He indicated that after he pulled my logs that there was a more serious (but not horrible) issue with "battery isolation." He apologized that he was not as familiar with the logs as the technicians are, but he felt that it had something to do with the battery heater.
(I told him that I thought something may be a little off, as the notification that I receive upon completion of charging would indicate that the battery was at 202RM, but when I would enter the car a few hours later, the rated miles were always down to around 192-194.) That seemed highly odd, as the lows here are not that terribly low (probably 45 degrees in the garage.)
So, the S85 will be picked up Wednesday morning and hauled to Monterey/Seaside.
Finally, what is interesting is that the return e*mail address refers to FresnoRangerService@teslamotors. However, apparently that address has not been created formally, as when I replied to the calendar appointment to thank them for prompt service, it was returned. (And yes, I just used the blue underlined link in the email that Tesla generated to me.)
Has anyone else experienced this sort of issue with the battery heater?
To my knowledge, there is is no way a high-voltage isolation fault can be traced to a particular component automatically be the car.
If the car detects an isolation fault, it may refuse to close the main contactor. If that happens, the DC-DC converter will not be powered and the car will issue the 12v system warning. Apparently the isolation fault must have cleared and the BMS finally closed it's contactors, otherwise you wouldn't have been able to drive.
For those that don't know, the high-voltage system is totally isolated from the chassis, and the BMS is constantly checking for leakage current to/from the high voltage system and the chassis. In the event the leakage current exceeds a certain threshold, it will indicate a fault and may lock out high-voltage power on start up. This is done for safety.
If the battery heater did have an insulation fault there is no real way for the car to know , and it would be up to the technicians to locate the fault by disconnecting parts of the system and measuring it until the find the leak.
I'm not (yet) sure exactly how Tesla does it, but it will involve checking resistance from each side of the pack to chassis and looking for leakage. The Prius did this with a square wave alternating between pack plus/minus and watching for current flow over a set threshold. I think the Tesla system also does some kind of a pre-closure check as well. This is all done inside the pack's sealed housing, so in the event of a fault, no high-voltage will come out of the pack.
It works almost like a GFCI (RCD) does on AC power.
Thanks for your explanation! I will update this thread as I receive information from service.
Here is the description per the invoice from Tesla Service:
Concern: Customer states Alert appeared: "Car Needs Service, Car May Not Restart", car
can restart.
Pay Type: Warranty
Corrections: Vehicle Alerts General Diagnosis
Pulled vehicle logs and found alerts for internally faulty battery coolant heater. Replace
coolant heater and re-check.
Corrections: Coolant Heater - Electric - Battery - 2nd Generation
Removed and replaced electric battery coolant heater. Verified no alerts present at this
time and vehicle is operating optimally.
Part Quantity
ELECTRIC BATTERY HEATER - RWD AND
DUAL MOTOR (1038901-00-G)
ETHYLENE GLYCOL COOLANT - 50/50 MIX
- 1 gallon (1029320-00-A)
Parts Replaced or Added
0.00
RONC9714000352
Apparently the battery heater was not operating properly from time-to-time. This conclusion was derived from the diagnostics that service received on my car. The way that I understood the service technician was that this error message is rather general instead of specific. Any sort of issue that concerns the main pack generates this sort of warning, as there could be much more serious problems which would cause the car to shut down permanently.
I did not know there was a separate battery heating module.
Yes, Battery heater (coolant), Battery chiller (shared with cabin) acting on coolant, and cabin air heater.
Same thing happened to me while charging at the Glen Allen SC last May. Tesla had to flatbed the car back to NC and gave me a loaner car to continue our trip to PA & back to NC again. Bad timing all around :)
Hi guys,
Got almost the same isue, 12v battery discharged, car does not drive, contactors don't close. I suppose there is an isolation issue. I can see in BMS data isolation res. 3580 kOhms, which looks normal. I suppose this is internal isolation.
It seams that BMS measures separate internal and external insulation. I have external insulation alert. However, BMS shows a good value for insulation, I suppose that one is internal as in the below pictures. Any idea if measuring the resistance between + and chassis respective - and chassis of each of the suspected high voltage components is the way to go ? I suppose values above 2000-3000 Kohms should be considered good insulation ?
HI, I now have the same issue "electric battery coolant heater" needs to be replaced. Tesla SC quoted me $1600. Is that normal? Anything I can do to ask them to reduce the est cost down? Seems to be TOO high. Thanks for your help in advance.
Like I said, you can either get a used one or a new one from Tesla over-the-counter at service (if they stock it). Calimotive is one of the largest Tesla dismantlers in the world, they'll probably have one. There is no "reconfiguration" or software, this is literally a dumb heater, 2 coolant lines, and 2 connectors. About the same as changing a thermostat in an ICE vehicle.
