TomT
Technical Maven
No, not true. Maintenance free lead acid batteries - which literally all vehicles that are not using an AGM use these days - are sealed and not vented. They do not gas unless seriously abused. Maintenance Free |A standard battery has vents for each shell otherwise they would pop off due to hydrogen gas generation. When you put a std battery on a charger you should remove the caps so the hydrogen doesn't accumulate. You can see it bubbling on the lead. When you add water to top off the battery , the missing water H2O had been turned into into hydrogen gas H2 previously.
