13-Year-Old Makes A Solar Breakthrough With Fibonacci Sequence
Discussion in 'Energy, Environment, and Policy' started by markwj, Aug 18, 2011.
  1. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    Stumbled across this one:
    13-Year-Old Makes A Solar Breakthrough With Fibonacci Sequence : TreeHugger
  2. rabar10
    rabar10 Model 3 >> Focus Electric
    Indianapolis, IN
  3. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I see a little problem with his method. He has his experiment setup next to a reflective surface which can't be utilized by the flat panels directed away from the reflective surface. Great experiment for a 13 year old though!
  4. dmckinstry
    dmckinstry Model S - U.S. P - #1649
    Medical Lake, WA (near Spokane)
    It is a great experiment. However, I have doubts about mounting for a large scale array. A tracking system would work as well, but is fairly expensive to implement.
  5. rolosrevenge
    rolosrevenge Dr. EVS
    He tested in different locations so that isn't a problem. His problem is linking a higher voltage to a proportionally higher power output. He needs to connect a resister and measure the power generated in each alignment. At maximum power generation, the panel will actually have lower voltages. I do think that this idea has promise though.
  6. markwj
    Hong Kong
    So, the reason the kid's approach doesn't work is that current solar tech requires the cells to be combined in series, and the output is governed by the worse performing cell? The kid / nature has just summed up each cell output. Trees don't suffer from this as each leaf (sic) is independent?
    Sounds like they are primarily debunking the current practical ability to extract power from this arrangement, not the arrangement itself.
    Another variant of the multiple-micro-inverter vs one-big-inverter battle?
  7. S-2000 Roadster
    I keep wondering if there's some way to pull the current out of solar panels and use it to directly charge my Tesla battery, rather than worrying about series voltages, boosting to 240 V, then rectifying from AC back to DC, etc. I suppose that any cell must see a higher potential in order for the current to flow into the cell, but perhaps there's a way to use boost rectification to build higher voltages than the individual solar cells produce on their own.
  8. JRP3
    JRP3 Hyperactive Member
    Central New York
    Am I the only one who sees the obvious problem? Unless I'm mistaken his "solar tree" is using a greater number of cells than his flat panel. I'm counting 17 cells on his "tree" compared to only 10 on the flat panel. Great effort but a bad experiment that proves nothing, and does not promote or teach good science.
