I was pleasantly suprised at getting abour 10 miles on the clock for every hour of charge. I am now wondering whether paying £800 for a home charger was really necessary!!!
I would take that with a pinch of salt. You will get 2.3kwh per hour max which if equal to 10 miles would equate to 230 wh/m. If you can average that at any time of the year never mind winter you are doing better than me!
At you rate this time of year that 10 miles per hours charging will equate to 7-8 miles.
But yes, if you don't regularly do long trips, 10A charging is perfectly feasible (even mostly within an off peak window) with a little thought and common sense.
Your home charger is much quicker so you can take advantage of much cheaper off peak rates that are time limited*. Also if you need to add a reasonable amount of range in a short(ish) period you are going to be better with your home charge point. It also adds further layers of safety by having a dedicated circuit, dedicated RCD and over current protection and more sophisticated earth protection.
*The UMC can actually also charge at 32 amps with the correct adapter but you would also need to install an appropriate spec circuit.
