I have a setup here on the farm with all sorts of electrical connections with varying plugs/breakers with 240 service and I have one 14-50 outlet that was used for a big electric motor that is no longer used so I plugged my 14-50 with the mobile connector into it and it seems to work great and I am getting 29 mph charge rate. It shows 32 amps and 246/247 volts. I researched what I could and seems like it shouldn't be an issue as it's not like I'm putting more power to the car with a 100 amp versus 50 amp breaker it just will give the connector what it needs with ease.
Also is it ok for the Gen 2 mobile connector to be used/left out in the rain? Not a permanent solution but something to use for now until I get my permanent solution done. Thanks!
