14-50 outlet - will it work if the voltage is 208V instead of 240V?
Discussion in 'Model S: Battery & Charging' started by Electricfan, Feb 3, 2016.
  1. Electricfan
    Electricfan Active Member
    Houston
    I have a 14-50 outlet at home I use for my car. My boss is installing one here at the office, but the electrical service here is different than I have at home. Something to do with at home I have single phase, vs here at work we have 3-ph, so the voltage is going to be 208V and not the higher 220 or 240 (can't remember, I'll measure when I get home) I have at home.
    Will the Tesla care? I assume it will still limit itself to 40a, with my single charger, so it will just charge more slowly at the lower voltage?
  2. ChrisPDX
    ChrisPDX Member
    Hillsboro, OR
    That won't be a problem. You'll just charge about 20% slower then on a normal 240v 14-50. Most public J1772 stations are 208v, so the cars have be compatible.
  3. Cottonwood
    Colorado
    Almost correct. 208 Volts is actually 13.3% lower than 240 Volts, and on 208 Volts, the Tesla will charge 13% slower than on 240 Volts for the same current.
    Many commercial locations have 208/120 Volt 3-phase service, as well as many RV parks. Teslas will charge just fine, but a little slower, on 208 Volts.
    You have a great boss, BTW, if she is willing to install EV charging outlets in the workplace!
  4. ChrisPDX
    ChrisPDX Member
    Hillsboro, OR
    Admittedly, I used 200v as that's what I always seem to get at commercial sites. Then my quick head math came up with 20% instead of 16.7%. Close enough. :)
  5. Barry
    Barry Active Member
    Colorado
    My home, a condo, is in a mixed use commercial/residential building and has 3 phase power. My daily (or nightly) charging is at 208V. At 40A, it charges at about 25 mi/hr. No problems at all.
  6. Fuma586
    Fuma586 Member
    Clinton Twp, MI
    I charge at work on 3 phase 208v. The tesla charging cord will accept 2 or 3 of the phases but prefers 3.
    The 208v I charge on is actually 191v once I start drawing from it and it charges at about 23 mph.
    Hope this helps.
  7. Electricfan
    Houston
    Yes, he's awesome - not only to install the outlet (although I am paying for it) but to pay me enough that I can own a Tesla!
