14-50 plug install at Issaquah/Sammamish...
Discussion in 'Northwest' started by tokuro, Jun 11, 2013.
Tags:
  1. tokuro
    tokuro Member
    Sammamish WA
    I just had 14-50 plug installed in my garage by "Accurate Electric" of Issaquah. it was done very professionally with good work. highly recommended, if you are in this area.
  2. Discoducky
    Discoducky Active Member
    Seattle
    Nice, if you don't mind, what was the cost and what materials were used?
  3. tokuro
    tokuro Member
    Sammamish WA
    $113 for permit, additional 775$ for the work.
    it was about 30ft run in total. From the main panel, he went up above celling (~5ft), another 20ft above celling going side way, 5ft down from celling to the plug. I have 2 supporting poles and the box is attached to one of those pole. He did ask me if I wanted a plastic vs metal box and I've opted for a metal box. Pipe coming down is a plastic one. He also had to move/re-arrange my breakers to make a space for 50A breaker.
    their cost is somewhat fixed and I could have it installed right next to the main panel. In that case, it would have been $364 instead of $ 775. & don't forget sales tax + trip fee ($59) on top of those.
    1st photo is "work in progress" from the main panel. 2nd one is finished photo of the plug and conduit.
  4. Palpatine
    Palpatine Banned
    Seattle
    I just had my NEMA 14-50 installed for $219.
    Get several quotes. Don't just take the first one.
  5. tokuro
    tokuro Member
    Sammamish WA
    Absaolutly agree. Always get a few vendors to bid. and yes i had a few.
  6. goneskiian
    goneskiian Active Member
    Bellevue WA
    I was just reading in another thread about infrastructure for EV's being exempt from WA sales tax. Would this qualify?
    Cheers!
  7. brianman
    brianman Burrito Founder
    My understanding is that 14-50 doesn't qualify, but I could be wrong.
  8. PhilBa
    PhilBa Active Member
    Seattle
    #8 PhilBa, Jun 13, 2013
    someone should pull up the RCW but a brief reading I did a month ago was that electrical work to support charging is also exempt. So, if your 14-50 is solely for the purposes of charging your car, it should be exempt.
  9. PhilBa
    Seattle
    Thanks. It's 1.c "infrastructure". As long as you can show that primary usage of the 14-50 is for an EV, you should be exempt from the tax. Not sure exactly how you do that with the average electrician.
  10. Puyallup Bill
    Puyallup Bill Member
    Puyallup WA
    Yes, that might be a problem with a small independent guy that doesn't have an office staff and such.
  11. DouglasR
    DouglasR Member
    United States
