150kw Supercharging
Pilot Steve
89
71
Milwaukie, Oregon
this was just sent to me from Tesla:. Thank you for reaching out to Tesla Support. Definitely a great question. Most Tesla owners will see an overall improvement in charge efficiency and peak charge rates, though not all will reach 150kW peak charge rates immediately. However, we expect the vast majority of our fleet (including all new models) to be 150kW capable within the next few months as we roll out further improvements. the peak rate each vehicle achieves will vary with size and age of battery pack, state of charge and ambient temperature conditions. There are a small number (<10%) of North America Supercharger stations that will not immediately deliver 150kW peak charge rates. Please consult the Supercharger pin in your vehicle UI to view the max charge capability of various Supercharger locations.
Your thoughts
HandleX
120
188
SF Bay Area
QUOTE="Pilot Steve, post: 3635617, member: 45622"]the update 2019.12.1.2 is the one with the 150kw charging correct?[/QUOTE]
I have 2019.12.1.2 and on a recent road trip my highest charge rate was 135kW
Silicon Desert
3,031
2,790
Sparks Nevada / GF 1
Your thoughts
Sounds like they are finally giving an answer that is more correct. That's what I would expect, except for that word "pin".
Reactions: P85_DA
BryWay
41
58
San Francisco, CA
I think in this context, the word "pin" refers to the location of the Supercharger -- from the practice of "dropping a pin" on a map, or "pinning" a location on a map. When I first read the original post, I thought there was a numeric PIN we'd need to enter (or retrieve) for this info.
Reactions: Silicon Desert
Anzir
663
476
Central Florida
Highest I've seen so far since the update was 132kW.
Reactions: P85_DA
Tam
8,261
7,114
Visalia, CA
What is this and where do you find it?
It's on your navigation. You can click on your map a Supercharger pin such as "A" below and it lists all its features including as in this case "150 kW max":
Hilbe
255
135
Fishers, IN
Hoping my 90D gets to 150kw at some point. It is a 400V pack afterall.
Will hit 2 or 3 superchargers tonight on a trip to see what I can get on my 90D.
dknisely
221
151
Seattle, WA
I was rather shocked to see 138 kW at about 52% SoC at Aberdeen over the weekend. There was only one other car at the 8-stall SC. [December 2018 Model X 100D, and I was navigating to the SC, so pre-heating might have been happening.]
Reactions: P85_DA
wdolson
7,418
9,916
Clark Co, WA
If u do u will be the first 90batt I have seen ;)
It makes sense that 100KWH packs can take a higher charge rate. The more cells in the pack, the higher the charge rate. The ultimate limit is how much an individual cell can take without damage. The more cells in the pack, the more power you can put in without causing damage.
A different chemistry may allow more power per cell, which can increase the total charge rate of the pack, but comparing packs with the same chemistry, you're limit is the number of cells.
Model S M.D.
Ludicrous Radiologist
Oct 31, 2015
986
1,437
TX
Went on a road trip over the weekend and pulled 126 kW at ~50% SOC. Previous high at about this SOC at this particular Supercharger was ~108 kW. I was also navigating to the SC, so on-route battery warmup may have helped a bit...
Reactions: FlatSix911
