16A home charging while visiting in France
vitesse
1,026
294
Hertfordshire (UK)
We bought the EU granny adaptor and got good charge overnight at our friends in France. We were able to go straight into their 2 pin socket in garage with no need for extension cables. Bought it from Tesla. Can’t remember price but it was less than £50.
This has to have some way of automatically dealing with the earthing issue as well? Can you remember what current it delivered?
Generator
255
461
London
I built a 16A adapter myself. It’s pretty simple.
IP rated French plug, 2.5mm2 SY armoured flex and a 16A commando trailing socket.
I’m pretty sure I’ve read that the latest UMC is insensitive to polarity, so this should reliably supply 16A single phase, which is enough to get me out of trouble.
Reactions: .jg.
vitesse
1,026
294
Hertfordshire (UK)
I’m pretty sure I’ve read that the latest UMC is insensitive to polarity, so this should reliably supply 16A single phase, which is enough to get me out of trouble.View attachment 504388
This is what I'm inclined to do :)
But I have the old UMC so I will need two cables with the earths wired oppositely.
What current do you reliably get via a 16A socket in France?
Generator
255
461
London
16A. The French plugs are a little more capable than our compromised UK plugs. No fuse in them to overheat.
you’ll want to wire the Line and Neutral opposite, leave the earth where it is!
Reactions: vitesse
Generator
255
461
London
For weight and cost savings, you only need one cable. Plus, a short length of cable with a 16A commando plug at one end, and a 16A commando at the other. Wire one of them the “wrong” way round, and you have a polarity reverser that just plugs in to the longer cable.
vitesse
1,026
294
Hertfordshire (UK)
I thought of that but was worried about too many metal/metal connections?
Adopado
4,282
3,243
Scotland
.. and put a bloody big permanent tag on it saying "WARNING REVERSED POLARITY"!
arg
1,815
1,816
Cambridge, UK
@arg might be able to confirm or allay my concerns?
Well, everything is a compromise, but I'd not be too concerned about an extra commando in the circuit - compared to all the other possible connectors, they have the most robust contacts.
Other solutions with their own pros and cons:
  • One cable, plus a screwdriver.
  • UMC with the Tesla Schuko adapter plus a Schuko-Schuko extension cable with the type of plug that will fit both French and Schuko sockets. The extension lead will only plug into a French socket one way round, but the UMC will plug into the other end of it either way round and you can get the reversal there.
Reactions: vitesse
vitesse
1,026
294
Hertfordshire (UK)
Where to get the Tesla schuko adapter? Do you get a full 16A with this?
PaulusdB
Mayor Gnomus Vintage Limb
Jul 12, 2013
6,690
6,468
Europe
I got mine from the Amsterdam Service Center as a free swap for the old NL Schuko type. The old type couldn’t be reversed into all sockets.
The UMC recognizes the adapter and limits charging to 13A.
The Tesla part number for the item is 1024005-02-B. So either get it from an UK SeC, or during your vist to the continent. Besides the French SeC’s, probably Belgian and Dutch centers will have it in stock just as well.
Reactions: Roy W.
vitesse
1,026
294
Hertfordshire (UK)
There must be a Tesla part number for the item. So either get it from an UK SeC, or during your vist to the continent. Besides the French SeC’s, probably Belgian and Dutch centers will have it in stock just as well.
OK, but I will try the DIY project first as that might work at 16A and act as an extension, too. And making the cable up will be fun :D
Reactions: Roy W.
vitesse
1,026
294
Hertfordshire (UK)
And by the way everyone - sorry for my confusing technical references - it's not earthing, it's the randomness of which terminal is live or neutral in France and I think, Belgium.
sixela
1,278
1,487
Boechout
These aren't supposed to be random in Belgium. Nor in France. Since 2002 they are supposed to have the correct polarity for the official CEE 7/7 "Schuko" adapter that fits on the UMC.
That is neutral on the left and live on the right when facing the wall socket.
It's just that some people have houses with the wiring done wrongly, especially in older houses that were wired pre-2002 (and haven't been audited for compliance since).
Oh, if you're in the Czech republic then the sockets are indeed wired differently -- you'll need to reverse polarity there.
As for the current the Schuko adapter (which does fit French/Belgian type E and German/Dutch type F sockets, as it has a CEE 7/7 plug) delivers: 13A.
Which, TBH, is roughly what's safe -- I wouldn't want to draw 16A on most household Schuko sockets (they are usually fused at 16A; while they are supposed to be rated for 16A many of the cheapo Chinese ones do get quite hot at 16A).
vitesse
1,026
294
Hertfordshire (UK)
Is 2.5mm flexible cable adequate for long periods of 16A/up to 250V current? It only seems to be rated for 13A? If I went for 4mm, would it fit the connectors?
Apologies to @arg once again - if you have a moment to advise - much appreciated! No hurry though, I just need to get the bits by the end of next week.
