"Parody" vs "parity".
.30 only fixes the air suspension issue, the rest of the warts with .28 are still present.
While some owners report dramatic improvements in .22 and .24, others report it made AP a lot worse and less stable. We're still not sure what leads to these differing observations.
you could be getting .30..So 17.17.17 is better? Should I update to .28?
17.24.28 is the tits.
I hope you do. Everyone should experience the advancement.Can’t wait to get it! Unless the rollout happens tonight it will miss the first half of my road trip but hopefully a bigger rollout happens before my return.
That is up to you.... 0.28 (now 0.30) is not a disaster to be frank.So 17.17.17 is better? Should I update to .28?
Yep, here is the response from my email query to Tesla:I called the SC to try to revert to 17.17.17, unfortunately there is no going back =(.
At this time, there is no path for vehicles to have firmware selectively downgraded to a past version. While we want you to enjoy the enhancements...
- There are cases where I will be in AP and for no reason (no over pass, no car in front, nothing) and it would brake hard, slowing from 60 or 65 down to 35 within seconds. Someone asked about his in another form and reported the service center told them that the GPS street speed limit detection (the speed limit detection based on GPS data) was not working correctly and it would sometimes think you were on a residential road with a much lower speed limit.
- When the speed limit changes (slows down) the rather than gradually slow down the car would hard brake. This happened to me a couple of times and it literally throws you forward. EDIT: To be fair, this also happened to me once or twice on older firmware -- it may nor may not have improved/degraded. I have not used .28/.30 enough to say for sure.
Still needs a lot of work in my opinion. As much as I like what it did well, I would rather back out to 17.17.17 if I could.
Just got my MX on Monday and was on .28 and now on .30. I experienced the sudden hard braking where the car thinks the speed limit changed. Its done it multiple times now in the same spot on my way to work even after the .30 update. Also when the speed limit does change from say 55 to 30 the car sees the sign and brakes hard to get down to speed both on .28 and on .30. In the test drive I did a month back, that car did not have the speed limit change braking issue.
This sounds really dangerous... especially for the folks behind you. Random braking is never good, particularly from highway speeds to surface street speeds.
I doubt you will get it over the air, from what I have been able to gather only people who have been through a service center have received it on AP2 cars.Waiting for this update is painful. I keep going down to the garage to see if its ready......
