It's been a couple months and it seems like my 17kw system should be making more. I modeled this out with pvwatts and it seems like I should still be making more than I am (been making in the 50's recently). Tesla hasn't been to helpful when I give them info from the modeling. They claimed to have done a remote diagnostic and said things are operating as they'd expect. I have 3 PWs that are almost never 100% charged, so I'm rarely ever capped (still pre-pto).
Notes:
MP1: 26 panels (400w each) = 10.4kwh @ 23 deg, 107 Azimuth
MP2: 16 panels (400w each) = 6.4kwh @ 23 deg, 287 Azimuth
When I model these out on PVwatts, I should still be making 70-80kwh/day in early October. I probably should have seen closer to 80-90/day in early august but only ever hit around 65 tops.
My friend helped me pull string data today. Looks like there are 5 strings which matches the plans. I'm assuming it's not string-inverter connections or inverter settings that are bad but probably an issue with some of the panels themselves or something aggregating the power from the panels within the strings. My brain is too smooth to figure out what to look for and call Tesla's attention to. Was hoping someone more familiar might have an idea. Would very much appreciate any help!
Notes:
"Battery power level":"93%
Combined power metrics":{
"site":6,
"solar":7780,
"battery":7370,
"load":15151.25
}"Grid Power":"0.01kW
Solar Power":"7.78kW
Battery Power":"7.37kW
Home Power":"15.15kW
"String Data":{
"A":{
"Current":6.94,
"Voltage":165.70000000000002,
"Power":1136.0,
"State":"PV_Active",
"Connected":true
"B":{
"Current":0.0,
"Voltage":-1.1999999999999993,
"Power":0.0,
"Connected":false
"C":{
"Current":3.62,
"Voltage":370.20000000000005,
"Power":1337.0,
"Connected":true
"D":{
"Current":3.45,
"Voltage":370.8,
"Power":1286.0,
"State":"PV_Active_Parallel",
"Connected":true
"A1":{
"Current":0.0,
"Voltage":0.40000000000000036,
"Power":0.0,
"Connected":false
"B1":{
"Current":0.0,
"Voltage":0.5,
"Power":0.0,
"Connected":false
"C1":{
"Current":7.86,
"Voltage":266.2,
"Power":2080.0,
"Connected":true
"D1":{
"Current":7.44,
"Voltage":266.2,
"Power":1974.0,
"Connected":true
