Would the car with 18" wheels be faster to 60 because of the less unsprung weight compared to 20" wheels? If that's the case why is Tesla selling larger wheels on their Performance?
Have to measure tire and wheel together for total weight.
There will be no difference in 0-60 time. Handling around corners is a different story.
Please explain why you think so. All things being equal with the exception of rotational mass, there will be a very quantifiable difference between two cars. This is a very well documented fact. Now, its possible Tesla is limiting the 0-60 times but that wont affect braking.
Re cornering forces, given a smooth surface, rotational mass will have less of an effect on cornering forces. If the surface is not smooth, it can effect grip, depending on the surface, shock design and several other factors.
David
It has to do with multiple factors.
The limits of the Primacy Eco tires will show up right away. There are tests out there showing how the braking distance is reduced and the skid-pad numbers increase when you throw on some performance tires.
We're talking about rims, not tires. You can install the same tire on your 18" as on 20".
The 20" wheels Tesla gives us are heavy but they fill in the wheel wells ... than the 18s they offer.
David
