19 and 21in wheel size and offsets and weights?
Discussion in 'Model S: Driving Dynamics' started by 4sevens.com, Aug 22, 2012.
  1. 4sevens.com
    4sevens.com Member
    Would like to know so that I can switch out the 21in performance wheels for a more comfortable 19in with possible wider tires for more rear grip :)
  2. iamsohai
    iamsohai Member
    PNW
    I would like to know too!
  3. mnx
    mnx 2013 P85
    Ancaster, Canada
    #3 mnx, Feb 6, 2013
    "OEM specs: 5x120 bolt pattern, 40mm offset, 64mm centerbore, hubcentric, M14x1.5 lugs with 170 N/m torque; per Jerry 33 (our resident wheel expert), don't want more than +/- 4mm on the new offset or +/- 2% on the revs/mile (anything more would prob need your speedometer/odometer calibrated) "
    from: Aftermarket wheels, specs and affects (not a range thread)
    The 19's are 19x8. I searched the forum for 21x and turned up nothing, so I can't tell you what the width is on the 21's...
    Weights:
    19" Wheels: 13.74kg ~30lbs each (according to a Tesla engineer)
    Tires: 27lbs each (according to Tire Rack for Eagle RS-A2 245/45 19")"
    21" Wheels: "the 21" wheels with Continental ExtremeContact DW tires weigh 61 pounds. Tirerack says those tires weigh 26 pounds, so the 21" wheels must be 35 pounds. "
    I added the wheels specs to the FAQ for future reference. Model S - FAQ - Tesla Motors Club - Enthusiasts & Owners Forum
  4. gsxrex
    gsxrex Member
    NorCal
    #4 gsxrex, Feb 6, 2013
    From the safety guide:
    19 inch
    Front 8.0J x 19
    Rear 8.0J x 19
    21 inch - silver
    21 inch - grey
    Front 8.5J x 21
    Rear 8.5J x 21
    Road wheel nut torque 175 Nm (129 lbf.ft)
    Tire specifications
    On 19 inch wheels:
    Goodyear Eagle RS-A2
    All P245/45R19 98V
    On 21 inch wheels:
    Continental Extreme Contact DWS
    All P245/35R21 96Y
  5. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    Please note that this is a typo from Tesla. The front and rear wheels are the same for 19". They are almost certainly 8.0Jx 19.
  6. gsxrex
    gsxrex Member
    NorCal
    Fixed. Don't want to be spreading more typos around. :biggrin:
