19" Tire Recommendations
Discussion in 'Model S: Driving Dynamics' started by milotron, Jun 10, 2013.
  1. milotron
    milotron Member
    Victoria BC
    After having a sidewall failure on a 21" tire before 2500 miles, and struggling to find replacement tires, I purchase a set of 19" wheels from Tesla. The 21's handle great, but I am concerned about day to day driving with these tires/wheels.
    I live in the Pacific Northwest and don't drive this vehicle in snow, but lots of rain. Any comments on the OEM 19" tires?
    Also, looking for recommendations on a three season, high performance tire that is quiet enough for the Model S? Any thoughts?
  2. mnx
    mnx 2013 P85
    Ancaster, Canada
    #2 mnx, Jun 10, 2013
    Michelin Pilot Super Sport, but they are not available in 245/45/R19 (you'd have to with a different size such as 255/45 or 245/40).
    The Continental DW comes in 19" so if you liked the 21's they may be an excellent option as well.
    I think the Bridgestone S-04 Pole Position are worth a look as well, good performance for a great price!
    Here's Tirerack's test results comparing the Continentals, Michelins and Bridgestone's referenced above.
    Tire Test Results : Clash of the Titans: Testing Two New Max Performance Summer Heavy Hitters
    That said, I find the OEM 19" Goodyears to be fine for everyday driving... Sure more performance would be nice. It's pretty easy to make the tires chirp and turn on the TC light in a straight line etc....
  3. milotron
    milotron Member
    Victoria BC
    Thanks for the feedback. What is the sound level like on the OEM Goodyears? I have the Michelin PS2s on the 21's and they are are quite quiet, especially compared to the pair of Nittos that I had to put on as there are no 21" PS2s to be found anywhere....
    I like the idea of a decent all season, but don't want to give up on all performance, and get a noisy tire as the Model S really makes it noticeable.
    I have the Nittos on the back and they traction is not as good as the PS2s in a straight line, even with my non-perf 85.
  4. jerry33
    Texas
    When new they are not that noisy, but I doubt they are as quiet as the MXM4. I'll be just as happy when they are gone.
  5. milotron
    milotron Member
    Victoria BC
    So it sounds like you wouldn't use the Goodyears if given the choice? I had some Michelin MXM tires on a Jetta before and wasn't really impressed with them in the wet. Have you had good experience with them?
    I was also considering the Continental DW but have heard that they are loud.
  6. brianman
    brianman Burrito Founder
    As mentioned in another thread, I'm curious about ways to evaluate tire noise across tire manufacturers and models. Where is your data regarding the quietness of MXM4 coming from? Thanks.
  7. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    I don't have experience with them but when I'm due for a new set, I'm going with the Michelin Primacy MXM4's.
  8. jerry33
    Texas
    In this case, personal experience with the MXV4 tire (the precursor to the MXM4). It was quiet down to the end of the tread life. My expectation is that Michelin will have kept the quietness.
  9. brianman
    Understood. Thanks.
  10. mnx
    mnx 2013 P85
    Ancaster, Canada
    That's the big debate for me... When my goodyears are worn out do I get something LRR like the MXM4's or something more sporty like the Pilot SS. :)
  11. jerry33
    Texas
    No one can answer that but you. It's fun vs. wallet.
  12. zdre
    zdre 40kWh Model S, Model 3LR
    St. Louis
    The Goodyear Eagle RS-A2 are on sale at TireRack right now for $139 each if anyone needs a replacement set.
  13. bellwilliam
    bellwilliam Member
    LA
    2 days after I got my S, I bought Bridgestone S04 to replace the Goodyear.....much better performance, but a bit loud.
    I am selling my Goodyear OEM for $400...200 miles old.
  14. kevincwelch
    kevincwelch Active Member
    Chicagoland
    Already thinking about summer.
    I am considering replacing my stock Goodyear tires with one of the following 19 inch tires (to fit the stock 19 inch wheels). What do people think about these tires? Are there some other ones that people used last summer that performed well in dry and wet conditions?
    Continental ExtremeContact DW
    Bridgestone Potenza S-04
  15. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Note that those Potenzas have terrible rolling resistance compared to its competitors... and even worse than the Super Sports (unfortunately not available in our stock 19" sizing), which significantly outperforms the S-04s. In any case, I'd eliminate them simply on the range reduction alone.
    http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=174
    Those Continentals are the same tires that go on the 21"s, and so are a relatively safe bet. Lots of people here have experience with them, so their strengths and weaknesses are well-known. They're not great, but they're relatively inexpensive, have good performance, and low rolling resistance for a summer tire.
    You might also consider the Michelin Pilot Sport 3 and the Hankook V12 EVO. The V12s are cheap and perform well, but are loud compared to others. The PS3s are relatively new, I believe, so I don't know much about them yet. I do know they're a slot below the Super Sports in performance, but unlike the SS are available in our size.
  16. 100thMonkey
    100thMonkey Member
    Seattle area
    I'm just across the pond from you with very similar conditions. it's wet and moderate here, I do very little snow driving and the occasional ICE skating rink conditions are simply best avoided with anything but chains. I've been very happy switching to the 19" turbine rials with the MXM4's. it made our P85+ quite a bit quieter and the handling is better than the cold performance rubber that can be had for the 21's. we dinged up our 21's quite a bit after being super careful and eventually gave up on them... not worth the hassle in these parts, IMHO!
  17. mnx
    mnx 2013 P85
    Ancaster, Canada
    My next set of 19's will likely be Nokian zLine. Low rolling resistance and excellent grip (comparable to the pilot super sports from what I can tell.) They don't come in the stock size so I'm going to grab them in 255/40R19.
  18. Gizmotoy
    Bay Area, CA
    Ugh. I wish TireRack would start carrying Nokians so we can get decent comparisons.
    Looks like Consumer Reports ties the zLines and the ExtremeContact DWs. Super Sports beat them both.
    http://www.moderntiredealer.com/blog/the-biss-list/story/2013/08/consumer-reports-michelin-leads-the-pack.aspx?prestitial=1
  19. mnx
    mnx 2013 P85
    Ancaster, Canada
    You're just looking at the overall rating number. Looks like the Zlines are better for wet braking and have lower rolling resistance while the supersports give better tread life. They both get "excellent" ratings for dry handling/breaking and wet handling. The DW are down a notch on the wet handling category.... I guess the super sports could be more "excellent" at handling etc... But it appears the DW, MPSS and Zlines are all very comparable according to CR.
    Does anyone else rate tires other than CR and Tirerack?
  20. Gizmotoy
    Bay Area, CA
    I don't have CR so I couldn't see the full report. All I had to go on was the overall. Thanks for the details.
