19" Tire Replacements?
Discussion in 'Model S: Interior & Exterior' started by aviators99, Mar 28, 2013.
  1. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    I've seen some stuff about where to get cheaper yet still high quality replacement tires for the 21", but haven't seen much on the 19". With my annual coming up in the next couple of weeks, I've been thinking about the subject.
    When the time comes, where should I be looking for new tires? The ideal theoretical situation would be if I could get cheaper yet quieter, better quality tires. I'll take cheaper at the same quality, or slightly more expensive and quieter (yet the same quality).
    Of course I'm comparing to what Tesla would sell me.
  2. Holden
    Holden Member
    DC
    For one, I would definitely advocate replacing the OEM all-seasons with some high-performance summer tires - they will be superior in all conditions you're likely to experience in Florida...
    - - - Updated - - -
    No way to edit posts here? Guess I have to add another.
    Let's see if this link works:
    http://www.tirerack.com/tires/TireSearchResults.jsp?tireIndex=0&autoMake=Tesla&autoYear=2013&autoModel=Model+S&autoModClar=&width=245/&ratio=45&diameter=19&sortCode=57376&skipOver=true&minSpeedRating=V&minLoadRating=S&tab=All
  3. Holden
    Holden Member
    DC
    From my link above, I'd recommend the Continental ExtremeContact DWs as probably the best overall for the money, and the Kumho Ecsta LE Sports as the best bargain tire...
  4. jerry33
    Texas
    After a few more posts, you'll be able to edit and do other things.
  5. aviators99
    Thanks for the link. Are they likely to last longer or shorter than the one Tesla sells?
  6. Holden
    Holden Member
    DC
    Yikes, I dunno.
    But, if you start a from-scratch search on Tire Rack, you will also be able to see the OEM tires listed (or you can plug them in yourself), then check both the "surveys" for each tire you're interested in, as well as the customer reviews - all sorts of information there to help you make a very informed decision.
    Weird: I checked the OEM tire (Goodyear Eagle RS-A2s, apparently), and there are no "surveys" for it, and only three customer reviews; must be brand-new.
  7. jerry33
    Texas
    The big problem with buying OE tires as replacements is that there will be tires that the automobile manufacturers rejected for not passing their own standards in the mix.
  8. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    For 19s, I will be replacing the Goodyears with Michelin Primacy MXM4. They are LRR (low rolling resistance, should increase range efficiency), better reviews, longer treadwear, better warranty, much better traction (probably best you can get for rain), higher comfort....etc..etc. Top notch IMO. http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Primacy+MXM4&partnum=445WR9MXM4P&vehicleSearch=true&fromCompare1=yes&autoMake=Tesla&autoYear=2013&autoModel=Model%20S%20&autoModClar=
