$1900 Nema 14-50 installation in a Condo, expensive or fair?
Entaum
25
3
Miami, FL
Hi all,
I just got quoted about $1900 for a 220 ft cable run in my condo garage for a 60amp circuit and a 14-50 outlet. My HOA was ok with the insllation and just required me to install a meter to charge me for the electricity. Install will require pulling a cable from the pool equipment panel, attaching it to the roof and through one wall..
From what I've been reading the price seems about right, but I wanted to hear from others what their quotes were in a situation similar to mine... Also any suggestions would be appreciated! :)
thanks!
jdw
695
1,332
Vancouver
I paid about $1800 to connect an HPWC with 50 Amp service in a condo - the run was about 75 feet and I also had to install a meter. In my opinion it was pricier than it should have been, but I had to use an electrician of the condos choosing. I was glad to have been allowed to install charging at all, but did feel like I was getting the special Tesla owner price.
jbcarioca
5,264
25,648
That price is a steal. Consider yourself lucky you can do it at all . . .
All of us in SoFl Condos would probably agree. I paid more than twice that and only got 208/30. I also had to go through a third party to meet Condo HOA rules, so there is an electricity markup as well as a monthly fee. As auger said, that price is a steal. With such a deal maybe you want a HPWC rather than a generic connection. I admit I like having a Tesla connector at home (mine is a Tesla conectar but NOT a HPWC.
Entaum
25
3
Miami, FL
For that distance you may want wire size of 60 Amp circuit (probably 6awg), but as TexasEV says, the breaker should be 50 Amp for a 14-50 receptacle.
That's what the electrician told me. With his distance there would be losses if he went with 50.
- - - Updated - - -
You are right. I asked him what the price difference would be for a 100amp install instead. I don't have the dual chargers nor the HPWC yet, but like to keep the option open in the future. :)
Ampster
1,779
476
Kenwood, California
Just to be clear, the larger wire size is what would be used for a higher amp circuit but the circuit breaker should be 50 Amps. It would be a 50 Amp circuit with bigger wire because of the distance.
  • Disagree
Reactions: Roland
Roland
145
65
Naples, FL
Meeting the electricians tomorrow at the condo we just purchased. Parking spot is in the corner so whatever I install will be under roof but exposed to the wind and rain. If only a 50 amp breaker and 40 amp service is available (may be limits on wire gauge that can be put in existing conduit) should I use a HPWC or Nema 14-50 with mobile connector?
Larry Chanin
President, Florida Tesla Enthusiasts
Aug 22, 2011
4,911
765
Sarasota, Florida
Hi Roland,
In a public place subjected to the elements a hard-wired HPWC would be safer with less liability issues. Imagine a child unplugging the outlet end of a Mobile Connector and jamming a metal object into a live 240 volt outlet..
Larry
auger
220
128
SoFL
That's probably true. I was just pointing out there are solutions to locking the plug into the NEMA outlet if someone was worried about tampering.
I do like the flexibility the NEMA 14-50 gives you--easy to change or exchange EVSEs in the future if the need arises.
jerry33
Mar 8, 2012
19,710
22,716
Texas
Hi Roland,
Larry
Most houses have external receptacles that are live, and except in the U.S. they are usually 220V. This hasn't been a big problem. Anyway, if you keep the UMC outside, it really should be in a weatherproof box with only the cable sticking out.
Roland
145
65
Naples, FL
Thanks for all responses. The electrician will be here today to look over my set up. Thanks for the link to lockable NEMA 14-50 boxes. I'll update with my options then.
Grease Monkey
New Member
Apr 10, 2016
3
Miami, FL
You might be required to put an additional means of disconnect, like this within line of sight, since you are defeating the regular means of disconnect (the plug). The locks are supposed to remain open when in use if no other means of disconnect are within line of sight. The locks on boxes are mostly meant to protect people servicing the circuits. This prevents someone from being electrocuted because someone else energized the circuit. More info here.
