19's on a P85D or P85+
Discussion in 'Model S: Driving Dynamics' started by EKnight47, Oct 10, 2014.
  1. EKnight47
    EKnight47 Member
    Milton, MA
    P85D only comes with 21''s?
    Any insight as to why the P85D only comes with the 21s? I have 21s for my current S85 and after going through 4 21" rims/tires in the months of May - July up here in Boston, I just put my 19s on and will probably keep it that way. Would love a P85D, but 21s won't do even in the summer....nevermind the snow!
    Thoughts?
  2. brianman
    brianman Burrito Founder
    Buy the car with the gray 21s. Trade/sell them to pick up 19s. ;)
  3. jweinstein
    jweinstein Member
    Anchorage, AK
    Will the car automatically adjust for the smaller rim size with regard to speed and accrued miles?
  4. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    Wheel size does not matter -- the outside diameter of the tires+wheels is the same (or close enough) between 19" and 21" rims.
  5. brianman
    In case you're asking me, re the 21s vs. the 19s... For TPMS, when you train it you tell it 19 or 21.
  6. rcc
    rcc Model S 85KW, VIN #2236
    San Jose, CA
    Because if you have a car with 0-60 times that are only 10% slower than the latest top-of-the-line Ferrari or McLaren and throttle response that's faster, the sidewall flex of the 19" tires makes a real difference. Putting 19" tires on it in the summer would be like DaVinci painting the Mona Lisa on velvet. If you're going to do that, I would think seriously about getting the 85D instead.
  7. Cottonwood
    Colorado
    I believe that the P85D has the same asymmetric front/rear wheel layout for the 21's as the P85+, but that is unclear to me at this point. Maybe someone has better info.
    I have an early P85 Sig with symmetric (same all around) 21's now and am considering a P85D. On the P85, it is easy to change to 19's with good Hakka snow tires for winter driving.
    Is a swap to 19's and snow tires possible and reasonable to do on the P85+ or the P85S with their asymmetric front/rear wheel layout for the 21's?
    - - - Updated - - -
    Well one clue that it is possible is that the Tesla Web order page will let you select a set of 19" snow tires as an option for the P85D.
    This could be a reality or a mistake in limitations programed into the order system. I would hope the former...
  8. AndreyATC
    AndreyATC Member
    Cape Coral FL, USA
    I'm running winter 19s on my P85+
    I dont see it as a problem regardless of the model
  9. jweinstein
    jweinstein Member
    Anchorage, AK
    That being said, is there an issue putting the 19 inch tires/rims on in the winter?
  10. mgboyes
    mgboyes Member
    United Kingdom
    The P85+ only came with 21" wheels and this is the replacement for the P85+ (and presumably includes all the suspension upgrades the P85+ had). So this isn't really surprising at all is it?
  11. HankLloydRight
    Connecticut
    I'm putting 19" wheels and all season tires on my P85+ for the winter. No issues.
    Sure, handling will be a tad different, but so would driving on 21" summer tires in 0 degree temps.
  12. brianman
    Presuming your referring to the hypothesis that the D comes with staggered wheels...
    It's not so much a surprise as a dashed hope. The hope that with AWD you don't need the staggered wheels. Perhaps Lola can come by and explain in simple terms why that hope was foolhardy to have in the first place. :)
  13. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    You're quoting straight-line numbers, though, and sidewall flex is primarily an issue during cornering until you're up into serious things like Top Fuel drags (side note: search YouTube for very cool videos of slow-motion Top Fuel tires at launch). The typical driver would struggle to notice any difference whatsoever in handling between the same tires (brand/model, not size) on a 19" and a 21" wheel. Indeed, the car I usually track has the same profile as the 19"s on an S and, for example, the McLaren F1 used 45s, the current Corvette uses 40s, and so forth.
    I think it's reasonable to expect that many people would daily drive the P85D and a stiff summer tire on 19"s (or, better, straight 20"s) would be an extremely attractive compromise that maintains straight-line performance, but gives up a little in cornering in favor of practicality (price, longevity). I also suspect many will be purchased in areas that see snow, and for winter use you want the smallest/narrowest tire you can put up with for use in the snow. For that 19"s will be a serious option.
  14. EKnight47
    EKnight47 Member
    Milton, MA
    Well....I don't live in San Jose CA. I live in Boston. I would argue that the roads here are older and have more potholes than any place in the country. I have 21s. I love them and would much rather have them on my current model s in the summer. But, even driving with the utmost caution, I ripped through an entire set of 21s in a matter of 2.5 months. After my fourth tire - I had enough and put on my 19s. I now have a brand new set of 21 rims/tires w/TPMS sitting in my barn and I just cannot seem to part with them. The bigger issue is that this is just the summer time argument. The 21s would likely be worthless to me Dec - Mid April.
    All this said.....I guess my question was whether putting 19s on a P85D was possible/recommended. And yes, I could just get an 85D....but I want the P85D - no matter how childish that sounds.
  15. HankLloydRight
    Connecticut
    IMO, there's no problem at all putting 19" on the P85D, P85+ or any other Model S.
  16. svp6
    svp6 Member
    MN
    Since the design center suggests winter tires for the P85D, and a 19" winter tire package is available with this option, I would presume 1) 19" clear the breaks and 2) nothing will happen if you keep 19" in summer (other than loosing some performance). I changed my p85+ order to p85d and asked for the 19" winter tires, no problem
  17. andrewket
    andrewket Well-Known Member
    #17 andrewket, Oct 11, 2014
    I sent a letter to Jerome and the general [email protected] alias regarding the lack of a 19" option on the P85D. Like many here, I think the 21's look great, and in many areas of the country the low profile tires are not an issue. But after going through many ties on my plus, I purchased aftermarket 19" wheels and tires. I asked Jerome to consider giving customers the option to make a choice that best fits their individual situation. If you feel strongly about this, I encourage you to let Tesla know.
  18. HankLloydRight
    Connecticut
    What they really should do is offer the Turbines in a 19" wheel from the factory.
    I still don't know why they don't do this, leading to the Rials and TSTs to fill the gap.
  19. CarlK
    CarlK Active Member
    SF Bay Area
    Absolutely. Lessor tires defeat the purpose of getting such a high performance car.
  20. andrewket
    I suggested this as well.
